Azureus not working out of the box [Solved]
scorp3000
Post by scorp3000 » Tue Jul 31, 2007 15:38
Just installed 3.4a. Azureus would not run. Any ideas?
edgevision
Post by edgevision » Tue Jul 31, 2007 15:42
Try opening a terminal window and running it from there, it might provide some helpful output.
tekwyzrd
Re: Azureus not working out of the box
Post by tekwyzrd » Tue Jul 31, 2007 17:05
scorp3000 wrote:Just installed 3.4a. Azureus would not run. Any ideas?
Same here. Re-emerged. Stil not working. Here's the output:
$UI not set defaulting to swt
File "/usr/bin/gjl", line 178, in ?
pkg = manager.get_package(options.package)
File "/usr/share/java-config-2/pym/java_config/EnvironmentManager.py", line 132, in get_package
all_pkg = self.get_packages()
File "/usr/share/java-config-2/pym/java_config/EnvironmentManager.py", line 145, in get_packages
self.load_packages()
File "/usr/share/java-config-2/pym/java_config/EnvironmentManager.py", line 90, in load_packages
for virt in self.get_active_vm().get_provides():
File "/usr/share/java-config-2/pym/java_config/EnvironmentManager.py", line 116, in get_active_vm
self.load_active_vm()
File "/usr/share/java-config-2/pym/java_config/EnvironmentManager.py", line 109, in load_active_vm
raise InvalidVMError
java_config.Errors.InvalidVMError
Couldn't get needed information
Former Sabayon user (2005 - 2013) and current Arch user.
I liked Sabayon until it switched to Rigo and becoming the gentoo equivalent of Ubuntu. Extreme browsing? Extreme gaming? Extreme work? Extreme development? Like, totally gnarly, dude!
edgevision
Post by edgevision » Tue Jul 31, 2007 17:33
Looks like a Java issue, not an Azureus issue.. maybe emerge/re-emerge your Java implementation? I've never had to do this and I don't use any Java apps (find them terribly slow) but maybe someone else can help with this.
Try testing other Java apps!
FrozenFox
Post by FrozenFox » Tue Jul 31, 2007 20:34
Sorry it's not something useful, but I have the same problem. Will post back with a solution when/if I find one ;P
scorp3000
Post by scorp3000 » Tue Jul 31, 2007 23:18
edgevision wrote:Looks like a Java issue, not an Azureus issue.. maybe emerge/re-emerge your Java implementation? I've never had to do this and I don't use any Java apps (find them terribly slow) but maybe someone else can help with this.
You are right. It's Java. I ran Azureus from the Terminal and the errors are all related to Java ( I'm not at the box now).I don't know how to fix it. I know I have to re-install JRE, but I don't know the exact name of the package and I'm to new to 'emerge' to know what I'm doing. In Ubuntu one goes to Synaptic>Search and you end up with your package. This is more complicated.
Post by wolfden » Wed Aug 01, 2007 0:19
java-config --list-available-vms
more java
http://www.gentoo.org/doc/en/java.xml
scorp3000
Post by scorp3000 » Wed Aug 01, 2007 3:24
more java
Thanks a lot!!
tekwyzrd
Post by tekwyzrd » Wed Aug 01, 2007 4:05
After a bit of experimentation I got it working after
emerge --sync && layman -S
emerge sun-jre-bin
at first run it complained about the swt version so I did
emerge swt
I don't think it made any difference but prior to the above I also did
emerge kdejava java-config-wrapper qtjava sun-java3d-bin javacc java-getopt
I'm seeding Sabayon v3.4 via azureus instead of ktorrent now that it's working again. :D
scorp3000
Post by scorp3000 » Wed Aug 01, 2007 16:01
Great info. Thanks.
