VirtualBox Problems [Solved]
Re: VirtualBox Problems [Solved]
Post by sabayonino » Sat Aug 01, 2020 12:03
https://wiki.gentoo.org/wiki/VirtualBox
]Windows guests
Emerge the app-emulation/virtualbox-additions package on the host system to get the Guest Additions ISO image that contains all necessary Windows guest drivers:
root #emerge --ask app-emulation/virtualbox-additions
VolvoBirkenstock
Post by VolvoBirkenstock » Sat Aug 01, 2020 22:46
Performing
results in
# emerge --ask app-emulation/virtualbox-additions
/usr/lib64/python3.6/site-packages/portage/package/ebuild/_config/KeywordsManager.py:70: UserWarning: /etc/portage/package.keywords is deprecated, use /etc/portage/package.accept_keywords instead
  UserWarning)
Performing Global Updates
(Could take a couple of minutes if you have a lot of binary packages.)
  .='update pass'  *='binary update'  #='/var/db update'  @='/var/db move'
  s='/var/db SLOT move'  %='binary move'  S='binary SLOT move'
  p='update /etc/portage/package.*'
/usr/portage/profiles/updates/4Q-2018.......
/usr/portage/profiles/updates/1Q-2019...............
 * IMPORTANT: 13 news items need reading for repository 'gentoo'.
 * Use eselect news read to view new items.
emerge: there are no ebuilds to satisfy "app-emulation/virtualbox-additions".
emerge: searching for similar names...
emerge: Maybe you meant any of these: app-emulation/virtualbox-guest-additions, app-emulation/virtualbox, app-emulation/virtualbox-modules?
So I attempted the following:
# emerge --ask app-emulation/virtualbox-guest-additions
  UserWarning)
emerge: there are no ebuilds to satisfy "app-emulation/virtualbox-guest-additions".
I note that I have already installed VIrtualbox Guest Additions and I can easily see that it is already installed by using Rigo. I can also see that it is installed by using "equo q files app-emulation/virtualbox-guest-additions-6.1.6#5.4.0-sabayon -qv".
The "equo install app-emulation/virtualbox-guest-additions" command did not produce an ISO image. HOWEVER, if it provides the functionality of the ISO image, then perhaps VirtualBox should not prompt me to upgrade Guest Additions by mounting the ISO image. If it does NOT provide the functionality of the ISO image and claims to support the functionality of the ISO image, then it is a design shortfall.
Post by sabayonino » Sat Aug 01, 2020 23:25
Disable "check for updates" in VB preferences
VolvoBirkenstock
Post by VolvoBirkenstock » Sun Aug 02, 2020 1:12
sabayonino, you are excellent!
That explains it well enough!
THANK YOU!
