After updating the system, errors in the programs. [Solved]
kris-kris
Post by kris-kris » Mon Jun 08, 2020 11:55
After the weekend update, the LibreOffice icons and bar do not display.
Operating System: Gentoo Linux
KDE Plasma Version: 5.18.4
KDE Frameworks Version: 5.70.0
Qt Version: 5.14.1
Kernel Version: 5.6.0-sabayon
OS Type: 64-bit
Processors: 4 × Intel® Core™ i5 CPU M 520 @ 2.40GHz
Memory: 3,6 GiB
edit:
Problem solved. In LibreOffice, Inkscape settings you need to change the theme and this fixes the display. There is a mistake, because the programs do not automatically download the system plasmas theme settings.
