Before I jump in neck deep...
Mercurybird
Post by Mercurybird » Wed Sep 04, 2019 2:11
Going full in with Sabayon. I have a longstanding Windows7 system that I need to keep viable in case I need to boot to it and get information and links from it. The 7 system is on a solid state drive. I want to get that onto another drive on the same system. It is a 500gb drive that it blank right now. So I can then wipe the SSD and put Sabayon on it so I can boot to either at will. I need help with porting my SSD to the SATA.
Thanks a cool million for your help.
Re: Before I jump in neck deep...
Post by albfneto » Wed Sep 04, 2019 20:27
If I understood you will wanto how to
"migrate" all your Windows in the SSD Hard disk, to a convencional new HD, further you want to install Sabayon on your SSD, is this?
This is not a Forum for Windows, but first, you need an Windows Program" for "clone" all your Windows in the SSD to the HD.
For example see, "Macrium Reflect" or search for another sofware for cloning Windows.
https://lifehacker.com/how-to-migrate-t ... ll-5837543
Mercurybird
Post by Mercurybird » Thu Sep 05, 2019 13:35
Thank you for your feedback. I got it installed the way I wanted to do it. It's on my SSD now. And W is on another drive. I really do like this distro.
Post by albfneto » Thu Sep 05, 2019 23:00
Please, mark the topic as [Solved].
add [Solved] to the title of the first topic.
iosman987
Post by iosman987 » Fri Mar 20, 2020 6:35
sys-kernel/linux-sabayon-5.4.17
x11-drivers/xf86-video-ati 19.1.0
lshw -c video
*-display
description: VGA compatible controller
product: Oland PRO [Radeon R7 240/340]
ometv chatroulette chatavenue
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: [email protected]:07:00.0
version: 87
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:59 memory:e0000000-efffffff memory:fce00000-fce3ffff ioport:e000(size=256) memory:c0000-dffff
thanks my issue is fixed.
