PysolFC
A place where Linux Gamers can share their experience and help each other with Linux Games, native or emulated ;)
zaivala
PysolFC
Post by zaivala » Sun Aug 11, 2019 1:15
I am new to Sabayon and so far am loving it. I have almost everything I use in my other distros (I'm a distroholic, even have my own podcast on the subject).
But I can't find PysolFC, a complete set of card games available on almost every distro. I do see some posts about this, with some successfully installing and using it, but the newest such post is from 2011.
Any clues what I should do here?
Re: PysolFC
Post by sabayonino » Sun Aug 11, 2019 10:33
Hi
Yu can get latest PysolFC releas over PIP
So, you can install dev-python/pip
# equo i dev-python/pip
Then you can get PysolFC (according on https://pypi.org/project/pysol-cards/#modal-close)
$ pip install --user pysol-cards
Collecting pysol-cards
  Downloading https://files.pythonhosted.org/packages/f4/f0/822c4db5a2fa9b29e01dd7485c1fd3bf70a2fba6e03fb38a04127d9a9017/pysol_cards-0.8.6.tar.gz
Requirement already satisfied: pbr>=2.0 in /usr/lib64/python3.6/site-packages (from pysol-cards) (5.1.1)
Requirement already satisfied: six in /usr/lib64/python3.6/site-packages (from pysol-cards) (1.12.0)
Installing collected packages: pysol-cards
  Running setup.py install for pysol-cards ... done
Successfully installed pysol-cards-0.8.6
zaivala
Re: PysolFC
Post by zaivala » Mon Aug 12, 2019 18:33
pysol-cards -- is that just the cardset, or the entire program? I'm used to downloading pysolfc and then pysolfc-cardsets.
Thanks for the help.
Re: PysolFC
Post by Fitzcarraldo » Wed Aug 14, 2019 14:25
There is a package for PysolFC in Portage (games-board/pysolfc), so you could file a request in the Sabayon Linux Bugzilla for it to be added to the Entropy repository.
Re: PysolFC
Post by joost » Thu Aug 15, 2019 19:56
requires to enable tk use flag on python. Not going to happen.
