Upgrade to kernel 5.1.5 induces mouse wheel problems
flexoron
Post by flexoron » Sat Jun 15, 2019 1:45
after switching to kernel 5.1.5, mouse wheel scrolling speed is decelerated.
Even firefox, chrome, terminals differ about that.
(Chrome dead slow, firefox slow, terminals stutter)
Needless to say, it is unusable.
It seems it is a hardware-independent kernel series 5 issue with scrolling.
Switched back to kernel 4.20 for now.
Does anybody experience similar problems?
Alexander88207
Re: Upgrade to kernel 5.1.5 induces mouse wheel problems
Post by Alexander88207 » Sat Jun 22, 2019 10:40
I cant confirm that.
How to create a sabayon uefi usb device: https://github.com/linuxerus/sabayon-st ... -device.md
flexoron
Re: Upgrade to kernel 5.1.5 induces mouse wheel problems [Solved]
Post by flexoron » Thu Jun 27, 2019 20:55
The problem goes away if not Roccat(Kone) mouse.
/lib/modules/4.20.0-sabayon/kernel/drivers/hid/hid-roccat.ko
/lib/modules/4.20.0-sabayon/kernel/drivers/hid/hid-roccat_kone.ko <--- Good
/lib/modules/5.1.0-sabayon/kernel/drivers/hid/hid-roccat.ko
/lib/modules/5.1.0-sabayon/kernel/drivers/hid/hid-roccat_kone.ko <--- Bad
In other words it is a kernel 5.1.0 roccat(kone) driver issue.
Not really solved and not really a serious issue.
thnx
Post by sabayonino » Thu Jun 27, 2019 21:18
Pay attention.
There are several "kone" drivers (without the underscore in the name)
ls /lib/modules/5.1.0-sabayon/kernel/drivers/hid/ | grep roccat
hid-roccat-arvo.ko
hid-roccat-common.ko
hid-roccat-isku.ko
hid-roccat.ko
hid-roccat-kone.ko
hid-roccat-koneplus.ko
hid-roccat-konepure.ko
hid-roccat-kovaplus.ko
hid-roccat-lua.ko
hid-roccat-pyra.ko
hid-roccat-ryos.ko
hid-roccat-savu.ko
Check wich files there was installed for both kernels (if both installed)
$ equo q files linux-sabayon:{5.1,4.20} | grep kone
╠  ### /lib/modules/5.1.0-sabayon/kernel/drivers/hid/hid-roccat-kone.ko
╠  ### /lib/modules/5.1.0-sabayon/kernel/drivers/hid/hid-roccat-koneplus.ko
╠  ### /lib/modules/5.1.0-sabayon/kernel/drivers/hid/hid-roccat-konepure.ko
╠  ### /lib/modules/4.20.0-sabayon/kernel/drivers/hid/hid-roccat-kone.ko
╠  ### /lib/modules/4.20.0-sabayon/kernel/drivers/hid/hid-roccat-koneplus.ko
╠  ### /lib/modules/4.20.0-sabayon/kernel/drivers/hid/hid-roccat-konepure.ko
flexoron
Post by flexoron » Fri Jun 28, 2019 0:56
yes...these are different Roccat models: Kone, Koneplus, Arvo, Lua ....
I've a Kone.
# lsmod | grep roccat
hid_roccat_kone    20480  0
hid_roccat         16384  1 hid_roccat_kone
Kernel 5 implements a feature called high resolution smooth scrolling, I guess.
Seems that Roccat drivers need adaption.
Next, I'll try to disable the driver but then I loose the ability manipulating
the mouse with these programs: roccateventhandler, roccatkoneconfig, roccatkonecontrol
thank you for the hint.
msdobrescu
Post by msdobrescu » Sun Aug 18, 2019 7:48
I have Logitech mice, I think they work fine, the drive also fine.
But, randomly, when I log into KDE, seems to be a problem that makes them "slow" regarding the wheel action.
It happens in 1/10 cases, and logging out and back solves the situation.
