baloo file extractor
Omnomnom9
Post by Omnomnom9 » Sun Mar 17, 2019 16:07
is it possible to disable the indexing from baloo file / baloo file extractor? I tried to uncheck the "index file content" in settings but it is started on every boot of the system.
Thanks in advance
Re: baloo file extractor
Post by Stupot » Mon Mar 18, 2019 0:28
Try using balooctl.
balooctl disable
Or to get the status:
balooctl status
To see all the options:
balooctl --help
