locked screen & hibernate (minor) issues
Finrod
Post by Finrod » Fri Feb 08, 2019 21:00
ok, now that the wifi problem is finally sorted :-) there are 2 more less pressing issues that I've had since I installed Sabayon on this Lenovo Ideapad 320.
Kernel is always 4.14 as the more recent ones don't seem to work well on this very finicky machine.
Now, one problem is when the screen is locked, if I hit anything the screen wakes but I'm asked for the password... and it's always, always rejected. I have to switch user, sort of as there's only one user here, and in that window... magick! Password is accepted and I can resume working on the laptop.
Not a terrible thing, but it would be quicker if the password worked without this fake switching. I wonder if it's a known problem, or it's just me (or it0s again a Lenovo thing...).
Another problem is hibernate: there's no way to wake up the laptop from it, also when it's "hibernated" after a few minutes fan starts working and the machine is quite warm. No problems with the suspend, except that I have to "switch" users...
Re: locked screen & hibernate (minor) issues
Post by Stupot » Sat Feb 09, 2019 1:27
Reinstall sys-libs/pam seems to be the trick to fix the lockscreen problem.
Finrod
Post by Finrod » Sat Feb 09, 2019 8:42
how should I do that? Thanks! :-)
Post by Stupot » Sun Feb 10, 2019 6:29
# equo install sys-libs/pam
Finrod
Post by Finrod » Sun Feb 10, 2019 14:23
thanks Stupot, I'm still a bit confused by the commands here :-)
Anyway, done it, and no change :-(
nearlyolddave
Post by nearlyolddave » Sun Feb 10, 2019 20:44
Having just installed sabayon ( after a long break), I to have this problem on a desktop, and cannot switch my one user to open, but as I update ( I loaded 18.04 ) I cheated,
Go to the start panel, > computer > system settings > desktop behavior and from the seven choices >screen locking and change from 5 minutes to 99minutes not a solution but stops the problem
Finrod
Post by Finrod » Mon Feb 11, 2019 20:01
yes, names are a bit different with Mate but I've managed to do it, thanks for the trick.
