Problem Installing RTL8821CE [Solved]
valdrio
Post by valdrio » Thu Jan 10, 2019 21:17
Hi, hope to be in the right section :)
I'm tryng to install the drivers for the wifi bluetooth combo RTL8821CE.
I enter the directory with the make file and then launch make, it stops with the following message:
CC [M]  /home/valdrio/asus/rtl8821ce/os_dep/linux/os_intfs.o
/home/valdrio/asus/rtl8821ce/os_dep/linux/os_intfs.c:1325:22: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
  .ndo_select_queue = rtw_select_queue,
/home/valdrio/asus/rtl8821ce/os_dep/linux/os_intfs.c:1325:22: note: (near initialization for ‘rtw_netdev_ops.ndo_select_queue’)
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:318: /home/valdrio/asus/rtl8821ce/os_dep/linux/os_intfs.o] Error 1
make[1]: *** [Makefile:1505: _module_/home/valdrio/asus/rtl8821ce] Error 2
make[1]: uscita dalla directory "/usr/src/linux-4.18.0-sabayon"
make: *** [Makefile:1902: modules] Error 2
Does someone have any idea on how to resolve?
Thanks in advance
Alexander88207
Re: Problem Installing RTL8821CE
Post by Alexander88207 » Tue Jan 15, 2019 13:31
I think you do it like i would do it?
sudo equo i sys-kernel/sabayon-sources:4.18 --ask
git clone https://github.com/tomaspinho/rtl8821ce.git
cd rtl8821ce
make
sudo make install
valdrio
Post by valdrio » Tue Jan 15, 2019 20:09
Yeah!!!
now it works, you trust me if i tell you that the only difference was that i downloaded it manually? Meaning with firefox and the extraxted the zip
Thank you very much
Edit: A last question if I update the kernel do i need to reinstall the drivers? thanks again
Alexander88207
Post by Alexander88207 » Tue Jan 15, 2019 22:37
nice to hear it works now & yes if you update the kernel you need to rebuild & install the driver :)
