X problems after last update
Freier Radikaler
Post by Freier Radikaler » Wed Jan 02, 2019 14:43
[email protected],
I just installed the recent weekly updates. As so often this results in issues... :cry:
This time systemd complains at boot time that not all Kernel modules could be loaded. "See systemctl status systemd-modules-load.services for details".
This shows:
● systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: disabled)
   Active: failed (Result: exit-code) since Wed 2019-01-02 10:32:37 CET; 4h 15min ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 1308 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 1308 (code=exited, status=1/FAILURE)
Jan 02 10:32:37 ThorsHammer systemd-modules-load[1308]: Failed to find module 'netbk'
Jan 02 10:32:37 ThorsHammer systemd-modules-load[1308]: Failed to find module 'blkbk'
Jan 02 10:32:37 ThorsHammer systemd-modules-load[1308]: Failed to find module 'xen-scsibk'
Jan 02 10:32:37 ThorsHammer systemd-modules-load[1308]: Failed to find module 'usbbk'
Jan 02 10:32:37 ThorsHammer systemd-modules-load[1308]: Failed to find module 'pciback'
Jan 02 10:32:37 ThorsHammer systemd-modules-load[1308]: Failed to insert 'xen_acpi_processor': No such device
Jan 02 10:32:37 ThorsHammer systemd-modules-load[1308]: Failed to find module 'blktap2'
Jan 02 10:32:37 ThorsHammer systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Jan 02 10:32:37 ThorsHammer systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Jan 02 10:32:37 ThorsHammer systemd[1]: Failed to start Load Kernel Modules.
I think it doesn't load logind as well which then leads to a non functional KDE. SDDM shows up and you can login for Plasma but after the loading bar is at 100% it only shows your background image an resets itself after a while so you end up in sddm again.
Systemd also complains about the following:
Jornalctl -xe shows:
Any ideas how to fix this? :?:
Freier Radikaler
Re: X problems after last update
Post by Freier Radikaler » Wed Jan 02, 2019 15:25
I just figured out that this seems to be my problem:
https://forums.gentoo.org/viewtopic-t-1 ... art-0.html
As soon as I generate the mentioned link (ln -s /var/run/dbus /run/dbus) for dbus and manually start the services it seems to work.
Post by joost » Thu Jan 03, 2019 13:24
There was a warning about this on the Entropy notificationboard as a forum topic about this a couple o weeks ago. I guess you missed this info somehow.
viewtopic.php?f=86&t=34902&hilit=%2Frun#p182998
