Sound pops and cracks
msdobrescu
Re: Sound pops and cracks
Post by msdobrescu » Fri Jul 26, 2019 10:24
Hello, any news on the matter?
Stupot, does it happen to have some USB bridge cards in some disk enclosure connected to the PC and powered on when the pops occur?
I have two, on a different controller than the soundcard, but playing from the two bridge cards.
The cards are based on JMicron chips, that had an old firmware, I call those "first generation firmware".
They had an issue I've found lately - could not support larger than 4TB disks unless the firmware was upgraded to a "second generation firmware".
After this, the pops disappeared.
Off topic, being JMS539 chips, have a sleep timer, that render the devices in an unrecoverable state, until the power down and on again, but I was lucky enough to solve the problem with the cards manufacturer (Lycom) that worked side by side with me and insisted to JMicron to get a "sleepless" firmware, despite the chips end of life was declared 4 years ago by JMicron.
I've seen a lot of trouble with these chips, and newer, regarding this sleep policy (probably due to the new environmental laws, but incorrectly applied technically speaking, IMHO). I hope you'll have the same chance with yours too, if it's the case.
For an idea, look here:
https://www.smartmontools.org/wiki/Supp ... SB-Devices
https://www.smartmontools.org/ticket/552
Post by Stupot » Tue Aug 13, 2019 14:38
I happened across this article today and I'm hopeful, because it matches my system specs (AMD, Ryzen, X370). Not sure if you'll fall into the same boat. https://www.phoronix.com/scan.php?page= ... t-Audio-WA
msdobrescu
Post by msdobrescu » Sun Sep 15, 2019 10:49
I didn't have any issues lately, seems that it is fixed.
msdobrescu
Post by msdobrescu » Thu Oct 03, 2019 17:01
Wrong! It's back!
Stupot, can you confirm?
I did not change any hardware, I've only updated the system.
msdobrescu
Post by msdobrescu » Fri Oct 25, 2019 18:57
The pops are now unbearable. It does not matter the volume, the pops are at maximum!
What fixed them for a while? Why are they back? Is it a regression?
Post by Stupot » Fri Oct 25, 2019 20:15
Interesting. I actually haven't heard any for a while. But it's hard to even recall if I made a tweak that helped or not. I was trying lots of random things and it's been a while....
Mine could have been fixed by the article I mentioned previously. The timing lines up, but I can't say for sure.
msdobrescu
Post by msdobrescu » Fri Oct 25, 2019 20:22
Yeah, the same, I don't remember what fixed it. I've tried lots and seemed to work out of the blue. And so came back. Possibly some upgrade overwrote some file... I wish I could reset the setup somehow. As freshly installed. But I don't even know what packages are involved. Or what driver, if there's any. It's a pain.
msdobrescu
Post by msdobrescu » Sat Nov 02, 2019 20:33
Stupot, could you please share some settings?
Post by Stupot » Wed Nov 06, 2019 0:23
I just looked, and I don't have any special settings in /etc/pulse/daemon.conf like I had previously tried. I never attempted to change any kernel parameters or compiling anything special. I think my issue was most likely addressed with the workaround implemented for AMD Ryzen systems that I linked in the phoronix article, and nothing that I ever did.
msdobrescu
Post by msdobrescu » Wed Nov 06, 2019 18:03
Thanks. I don't have an AMD, but it seems to be less aggressive lately.
I'm baffled.
