Does eselect lists not installed icedtea? [Solved]
msdobrescu
Post by msdobrescu » Fri Dec 28, 2018 16:57
I have the following output:
eselect java-vm list
Available Java Virtual Machines:
grep: /usr/share/java-config-2/vm/icedtea-7: No such file or directory
grep: /usr/share/java-config-2/vm/icedtea-bin-7: No such file or directory
  [1]   icedtea-7
  [2]   icedtea-bin-7
  [3]   icedtea-bin-8  system-vm
I have no package to remove for [1] and [2] above.
equo search --installed icedtea
╠  @@ Searching...
╠      @@ Package: dev-java/icedtea-bin-3.9.0-r1 branch: 5, [__system__]
╠          Installed:     version: 3.9.0-r1 ~ tag: NoTag ~ revision: 0
╠          Slot:          8
╠          Homepage:      http://icedtea.classpath.org
╠          Description:   A Gentoo-made binary build of the
╠                         IcedTea JDK
╠          License:       GPL-2-with-classpath-exception
╠      @@ Package: dev-java/icedtea-sound-1.0.1 branch: 5, [__system__]
╠          Installed:     version: 1.0.1 ~ tag: NoTag ~ revision: 0
╠          Slot:          0
╠          Description:   Plugins for javax.sound
╠          License:       GPL-2-with-linking-exception
╠      @@ Package: dev-java/icedtea-web-1.6.2 branch: 5, [__system__]
╠          Installed:     version: 1.6.2 ~ tag: NoTag ~ revision: 1
╠          Slot:          0
╠          Description:   FOSS Java browser plugin and Web
╠                         Start implementation
╠          License:       GPL-2 GPL-2-with-linking-exception LGPL-2
╠   Keywords:  icedtea
╠   Found:     3 entries
[code]
How to cleanup?
Thanks.
Re: does eselect lists not installed icedtea?
Post by sabayonino » Fri Dec 28, 2018 17:43
dead deps in your system
$ ls /usr/share/java-config-2/vm
... icedtea-8  icedtea-bin-8  oracle-jre-bin-1.8
check icedtea
equo q belongs /usr/share/java-config-2/vm/icedtea-7
╠  @@ Ricerca Appartenenza
╠   Keyword:  /usr/share/java-config-2/vm/icedtea-7
╠   Trovati:  0 voci
and
equo q belongs /usr/share/java-config-2/vm/icedtea-bin-7
╠   Trovati:  0 voci
remove older
msdobrescu
Post by msdobrescu » Fri Dec 28, 2018 23:31
Hi, thank you for replying.
icedtea-bin-8
╠  @@ Belong Search
╠   Found:    0 entries
╠  @@ Belong Search
╠   Keyword:  /usr/share/java-config-2/vm/icedtea-bin-7
╠   Found:    0 entries
Still no clues.
Post by Fitzcarraldo » Fri Jan 18, 2019 19:42
[email protected] ~ $ eselect java-vm list
  [1]   icedtea-bin-8  system-vm
[email protected] ~ $ ls /usr/share/java-config-2/vm
icedtea-bin-8
[email protected] ~ $ ls -la  /usr/lib/jvm
total 184
drwxr-xr-x   2 root root   4096 Jan  7 00:16 .
drwxr-xr-x 159 root root 180224 Jan  7 11:38 ..
lrwxrwxrwx   1 root root     22 Oct 22 11:13 icedtea-bin-8 -> /opt/icedtea-bin-3.9.0
Check if you have any old symlinks in the directory /usr/lib/jvm/ and delete them if you do.
msdobrescu
Post by msdobrescu » Sat Jan 19, 2019 10:14
  [1]   icedtea-7
  [2]   icedtea-bin-7
icedtea-bin-8
ls -la  /usr/lib/jvm
total 292
drwxr-xr-x   2 root root   4096 Oct 31 23:34 .
drwxr-xr-x 292 root root 290816 Jan 18 09:35 ..
lrwxrwxrwx   1 root root     19 Aug 15  2013 icedtea-7 -> /usr/lib64/icedtea7
lrwxrwxrwx   1 root root     24 Jun  8  2013 icedtea-bin-7 -> /opt/icedtea-bin-7.2.3.9
lrwxrwxrwx   1 root root     22 Oct 13 21:14 icedtea-bin-8 -> /opt/icedtea-bin-3.9.0
Post by Fitzcarraldo » Sat Jan 19, 2019 13:05
Fitzcarraldo wrote:Check if you have any old symlinks in the directory /usr/lib/jvm/ and delete them if you do.
msdobrescu
Post by msdobrescu » Sat Jan 19, 2019 13:09
Right, but they are not orphans, there are files in those paths. What should I do?
I usually try to uninstall the package that installed them, but I have no clue of that.
Post by Fitzcarraldo » Sat Jan 19, 2019 14:58
Delete the old symlinks in the directory /usr/llib/jvm/ (look at their file dates in the output you posted: 2013). Delete any redundant icedtea-bin-* directories. My sane, up-to-date installation has the following icedtea-bin directories:
sabayon /home/fitzcarraldo # ls /opt/icedtea-bin-*
/opt/icedtea-bin-3.5.1:
jre  lib
/opt/icedtea-bin-3.7.0:
jre  lib
/opt/icedtea-bin-3.8.0:
jre  lib
/opt/icedtea-bin-3.9.0:
bin  include  jre  lib  man
You should regularly: a) update the local database containing a list of available packages and their versions; b) upgrade installed packages to their latest available version; c) check and fix dependencies and libraries; d) remove any old versions of installed packages:
# equo update
# equo upgrade
# equo conf update
# equo deptest
# equo libtest
# equo upgrade --purge
# equo cleanup
I remove the packages that equo tells me to remove manually. I have found that sometimes the command ‘equo upgrade --purge‘ does not report all the packages that have to be removed manually. I therefore repeat that command a few times until no more packages are listed for removal.
Also, if you don't have it installed, install the package sys-apps/mlocate and periodically run the command 'updatedb' as root user to refresh the file index. Then you can use the command 'locate <filename>' to easily search for any file(s).
msdobrescu
Post by msdobrescu » Sat Jan 19, 2019 22:03
Thanks, I know these, I actually do these too. Seems some things were left behind at some point. I don't know how much. I would have liked to clean them up, but seems difficult to track them.
As for ls /opt/icedtea-bin-*, in my case there are several directories (empty, just directories inside) left from all the previously installed versions. I think it's safe to delete those.
