How to disable rigo daemon and magneto.py? [Solved]
s_verma
Post by s_verma » Sun Dec 16, 2018 18:27
Hi all,
I want to disable the rigo daemon and magneto.py application as I use command line equo for package management.
How can I do it?
PS: I deleted /etc/xdg/autostart/magneto.desktop which autostarts magneto, but still I see it as a running process.
Thanks.
Re: How to disable rigo daemon and magneto.py?
Post by Fitzcarraldo » Mon Jan 07, 2019 2:10
If you really have no use for Magneto and Rigo, you could uninstall them:
equo remove magneto-core magneto-loader rigo rigo-daemon
s_verma
Post by s_verma » Tue Jan 15, 2019 9:49
Thanks. But I wanted to know how do I disable the autostart.
I just got the answer. I turned off KDE restore session. Now it doesn't autostart.
