Equo upgrade error [Solved]
denijane
Post by denijane » Thu Dec 13, 2018 0:17
I just reinstalled Sabayon on my new hard and I tried to run
$equo upgrade
but got the following error:
Source Package Manager is too old, please update it: UsuportedAPIException()
I read somewhere in the forum that the problem is with the stable release and one should use the daily iso, however, it's already installed so I'd like to know if there is any way to repair entropy without reinstalling everything.
Re: Equo upgrade error
Post by joost » Thu Dec 13, 2018 12:13
I'd try this:
equo install equo entropy --relaxed
Then try to upgrade again.
denijane
Post by denijane » Thu Dec 13, 2018 17:26
Nope,same error
denijane
Post by denijane » Thu Dec 13, 2018 18:43
Well, I did
#equo install equo entropy --nodeps
#equo install binutils portage --nodeps
#equo upgrade
Still installing. Don't know if it will produce a working OS,but who cares,it's either that or fresh install, lol :)
Edit: Ok, this really helped,system upgraded normally. So yay! :)
ethicalfive
Re: Equo upgrade error [Solved]
Post by ethicalfive » Wed Jan 23, 2019 15:31
This link should be corrected with this solution. Both me and another user joined the sabayon irc channel (at the exact same time!) with this exact problem while following that wiki( https://wiki.sabayon.org/index.php?title=En:Entropy ) and getting the same error. We were told there is no solution and to download the latest daily. Which would have been quite annoying.
