GNOME gdm service does not start after upgrade
flexoron
Post by flexoron » Wed Dec 05, 2018 23:09
again: After updating yesterday(see below), GNOME gdm login service did not start.
Instead, I got a login-shell and found a broken link:
# cd /etc/systemd/system
# ls -l
... display-manager.service -> /usr/lib64/systemd/system/gdm-plymouth.service
# systemctl status display-manager.service
Unit display-manager.service could not be found.
# ls -l /usr/lib64/systemd/system/gdm-plymouth.service
ls: cannot access ....
Solution:
# rm display-manager.service
# systemctl enable gdm-plymouth.service
# ls -l
... display-manager.service -> /lib/systemd/system/gdm-plymouth.service
# ls -l /lib/systemd/system/gdm-plymouth.service
... /lib/systemd/system/gdm-plymouth.service
And I don't like Wayland:
# cd /etc/gdm
# vi custem.conf
WaylandEnable=false
# systemctl reboot
Maybe this update caused the misbehavior:
## U [sabayonlinux.org] sys-boot/plymouth-0.8.9_pre1-r3|1 [0.8.9_pre1-r3|0]
systemd gdm-plymouth.service moved to /lib/systemd/system
Re: GNOME gdm service does not start after upgrade
Post by albfneto » Wed Dec 05, 2018 23:40
You tried to verify the status of the gdm in the services of systemd?
# systemctl status gdm.service
i dont use gdm or GNOME, bui i use KDE and their login manager, sddm...
and for good working the service of the sddm should be running:
sudo systemctl status display-manager.service
Senha:
● sddm.service - Simple Desktop Display Manager
   Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2018-12-05 16:54:28 -02; 3h 55min ago
     Docs: man:sddm(1)
           man:sddm.conf(5)
 Main PID: 858 (sddm)
    Tasks: 8 (limit: 4915)
   Memory: 100.3M
   CGroup: /system.slice/sddm.service
           ├─858 /usr/bin/sddm
           └─875 /usr/libexec/Xorg -nolisten tcp -auth /var/run/sddm/{7727142e-801a-4031-8ab4-3643e470b5c9} -back>
dez 05 14:54:52 sabayon.local sddm-helper[1134]: [PAM] Preparing to converse...
dez 05 14:54:52 sabayon.local sddm-helper[1134]: [PAM] Conversation with 1 messages
dez 05 14:54:52 sabayon.local sddm-helper[1134]: pam_kwallet5(sddm:auth): (null): pam_sm_authenticate
dez 05 14:54:52 sabayon.local sddm-helper[1134]: [PAM] returning.
dez 05 14:54:52 sabayon.local sddm[858]: Authenticated successfully
dez 05 14:54:52 sabayon.local sddm-helper[1134]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
dez 05 14:54:52 sabayon.local sddm-helper[1134]: pam_unix(sddm:session): session opened for user albfneto by (uid>
dez 05 14:54:53 sabayon.local sddm[858]: Session started
dez 05 14:54:53 sabayon.local sddm[858]: Auth: sddm-helper exited successfully
dez 05 14:54:53 sabayon.local sddm[858]: Greeter stopped.
The output of the command:
# systemctl status sddm.service
shows started and running the sddm.service.
flexoron
Post by flexoron » Thu Dec 06, 2018 0:02
Yes, I did!
gdm.service works, too but gdm-plymouth.service is somehow cleaner.
# ls -l
... display-manager.service -> /usr/lib/systemd/system/gdm.service
# ls -l /usr/lib/systemd/system/gdm.service
... /usr/lib/systemd/system/gdm.service
Thanks for the hint.
BTW
There is another broken link:
# cd /etc/systemd/system/multi-user.target.wants
# ls -l
... irqbalance.service ->/usr/lib64/systemd/system/irqbalance.service   <-- broken
# rm irqbalance.service
# ln -s /lib64/systemd/system/irqbalance.service irqbalance.service
# systemctl restart irqbalance.service
Post by albfneto » Thu Dec 06, 2018 0:12
My system is not similar as yours. I use Sabayon KDE, my system not have some of the *-plymouth.services, nor irqbalance:
# systemctl status irqbalance.service
Senha:
Unit irqbalance.service could not be found.
my service kdm-plymouth.service is unloaded, since kdm no more exists. Look, this is SystemdGenie (one GUI for systemd in KDE):
https://i.postimg.cc/hvPS7Q7W/servicos.png
flexoron
Post by flexoron » Thu Dec 06, 2018 0:41
The problem as such has nothing to do with GNOME or KDE.
Perhaps it is a package upgrade issue.
If the new version moves its systemd service file to another location (here from /usr/lib64 to /lib)
it might recreate(if enabled) its 'enable link' in /etc/systemd/..., too?
