Auto-logout after weekly update [Solved]
VolvoBirkenstock
Re: Unusable: Auto-logout after weekly update
Post by VolvoBirkenstock » Sat Dec 01, 2018 21:33
I decided to post excerpts from "dmesg" and "journalctl -xb", thinking that it might help diagnose the issue. What is provided below is from my desktop. Note that this all apparently occurs subsequent to my use of "Control D" in response to the following message provided during boot:
Starting version 239
You are in emergency mode.  After logging in, type "journalctl -xb" to view
system logs.  "systemctl reboot" to reboot, "systemctl default" or exit
to boot into default mode.
Give root password for maintenance
(or press Control-D to continue):
The only "error" found in dmesg output:
[   16.685002] udisks-lvm-pv-e[930]: segfault at 0 ip 000055d275620069 sp 00007ffc65a825d0 error 4 in udisks-lvm-pv-export[55d27561f000+2000]
The following "error" list has been extracted from an extensive "journalctl -xb" output":
Dec 01 13:13:00 Gandalf systemd[1]: Starting Show Plymouth Boot Screen...
-- Subject: Unit plymouth-start.service has begun start-up
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit plymouth-start.service has begun starting up.
Dec 01 13:13:00 Gandalf systemd-modules-load[623]: Failed to find module 'pciback'
Dec 01 13:13:00 Gandalf systemd-modules-load[623]: Failed to insert 'xen_acpi_processor': No such device
Dec 01 13:13:00 Gandalf systemd-modules-load[623]: Failed to find module 'blktap2'
Dec 01 13:13:00 Gandalf systemd[647]: plymouth-start.service: Executable /usr/bin/udevadm missing, skipping: No such file or directory
-- Subject: Process /usr/bin/udevadm could not be executed
-- The process /usr/bin/udevadm could not be executed and failed.
-- The error number returned by this process is 2.
Dec 01 13:13:00 Gandalf systemd[648]: plymouth-start.service: Executable /usr/bin/udevadm missing, skipping: No such file or directory
Dec 01 13:13:00 Gandalf systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Dec 01 13:13:00 Gandalf systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Dec 01 13:13:00 Gandalf systemd[1]: Failed to start Load Kernel Modules.
-- Subject: Unit systemd-modules-load.service has failed
-- Unit systemd-modules-load.service has failed.
-- The result is RESULT.
<snippage>
Dec 01 13:13:04 Gandalf systemd[899]: plymouth-start.service: Executable /usr/bin/udevadm missing, skipping: No such file or directory
Dec 01 13:13:04 Gandalf systemd[900]: plymouth-start.service: Executable /usr/bin/udevadm missing, skipping: No such file or directory
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to insert 'xen_gntalloc': No such device
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'xen-blkback'
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'xen-netback'
Dec 01 13:13:04 Gandalf systemd[1]: Started Show Plymouth Boot Screen.
-- Subject: Unit plymouth-start.service has finished start-up
-- Unit plymouth-start.service has finished starting up.
-- The start-up result is RESULT.
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to insert 'xen_pciback': No such device
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'evtchn'
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'gntdev'
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'netbk'
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'blkbk'
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'xen-scsibk'
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'usbbk'
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'pciback'
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to insert 'xen_acpi_processor': No such device
Dec 01 13:13:04 Gandalf systemd-modules-load[891]: Failed to find module 'blktap2'
Dec 01 13:13:04 Gandalf systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Dec 01 13:13:04 Gandalf systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Dec 01 13:13:04 Gandalf systemd[1]: Failed to start Load Kernel Modules.
<snippage>
Dec 01 13:13:05 Gandalf lvmetad[628]: WARNING: Ignoring unsupported value for cmd.
Dec 01 13:13:05 Gandalf lvmetad[628]: Internal error: Bad format string at 'NONE'
Dec 01 13:13:05 Gandalf kernel: udisks-lvm-pv-e[930]: segfault at 0 ip 000055d275620069 sp 00007ffc65a825d0 error 4 in udisks-lvm-pv-export[55d27561f000+2000]
Dec 01 13:13:05 Gandalf systemd[1]: Created slice system-systemd\x2dcoredump.slice.
-- Subject: Unit system-systemd\x2dcoredump.slice has finished start-up
-- Unit system-systemd\x2dcoredump.slice has finished starting up.
<snippage>
Dec 01 13:14:29 Gandalf systemd-udevd[668]: Process 'udisks-lvm-pv-export kekKvx-p5mU-XKfI-PRdi-AxfT-mtHB-2hhVn3' terminated by signal SEGV.
Dec 01 13:14:29 Gandalf systemd-coredump[955]: Process 930 (udisks-lvm-pv-e) of user 0 dumped core.
-- Subject: Process 930 (udisks-lvm-pv-e) dumped core
-- Documentation: man:core(5)
-- Process 930 (udisks-lvm-pv-e) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
<snippage>
Dec 01 13:18:03 Gandalf avahi-daemon[1181]: Loading service file /services/sftp-ssh.service.
Dec 01 13:18:03 Gandalf systemd[1272]: plymouth-start.service: Executable /usr/bin/udevadm missing, skipping: No such file or directory
Dec 01 13:18:03 Gandalf systemd[1]: Started Avahi mDNS/DNS-SD Stack.
-- Subject: Unit avahi-daemon.service has finished start-up
-- Unit avahi-daemon.service has finished starting up.
<snippage>
Dec 01 13:18:03 Gandalf systemd[1274]: plymouth-start.service: Executable /usr/bin/udevadm missing, skipping: No such file or directory
Dec 01 13:18:03 Gandalf systemd[1]: Started Make remote CUPS printers available locally.
-- Subject: Unit cups-browsed.service has finished start-up
-- Unit cups-browsed.service has finished starting up.
<snippage>
-- Unit UNIT has begun starting up.
Dec 01 13:18:17 Gandalf systemd[1647]: dbus.socket: Executable /usr/bin/systemctl missing, skipping: No such file or directory
-- Subject: Process /usr/bin/systemctl could not be executed
-- The process /usr/bin/systemctl could not be executed and failed.
<snippage>
Dec 01 13:19:22 Gandalf systemd[1919]: dbus.socket: Executable /usr/bin/systemctl missing, skipping: No such file or directory
<snippage>
Dec 01 13:19:27 Gandalf klauncher[1977]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Dec 01 13:19:29 Gandalf kdeinit5[1983]: Initializing  "kcm_mouse" :  "kcminit_mouse"
Dec 01 13:19:29 Gandalf kdeinit5[1983]: Initializing  "kcm_style" :  "kcminit_style"
Dec 01 13:19:30 Gandalf dbus-daemon[1950]: Activating service name='org.kde.ActivityManager'
Dec 01 13:19:30 Gandalf dbus-daemon[1950]: Successfully activated service 'org.kde.ActivityManager'
Dec 01 13:19:31 Gandalf dbus-daemon[1950]: Activating service name='org.kde.kglobalaccel'
Dec 01 13:19:31 Gandalf dbus-daemon[1950]: Successfully activated service 'org.kde.kglobalaccel'
Dec 01 13:19:31 Gandalf kconf_update[2011]: "Missing \"Version=5\", file '/usr/share/kconf_update/katomic-levelset.upd' will be skipped."
Dec 01 13:19:31 Gandalf kconf_update[2011]: "Missing \"Version=5\", file '/usr/share/kconf_update/kcalcrc.upd' will be skipped."
Dec 01 13:19:31 Gandalf kconf_update[2011]: "Missing \"Version=5\", file '/usr/share/kconf_update/kgthemeprovider-migration.upd' will be skipped."
Dec 01 13:19:31 Gandalf kconf_update[2011]: "Missing \"Version=5\", file '/usr/share/kconf_update/klickety.upd' will be skipped."
Dec 01 13:19:31 Gandalf kconf_update[2011]: "Missing \"Version=5\", file '/usr/share/kconf_update/knavalbattle.upd' will be skipped."
Dec 01 13:19:31 Gandalf kconf_update[2011]: "Missing \"Version=5\", file '/usr/share/kconf_update/konversation.upd' will be skipped."
Dec 01 13:19:32 Gandalf org.kde.ActivityManager[1950]: Service started, version: 7.0.0
Dec 01 13:19:35 Gandalf kdeinit5[1983]: Initializing  "kcm_access" :  "kcminit_access"
Dec 01 13:19:35 Gandalf kaccess[2039]: Xlib XKB extension major= 1  minor= 0
Dec 01 13:19:35 Gandalf kaccess[2039]: X server XKB extension major= 1  minor= 0
Dec 01 13:19:35 Gandalf dbus-daemon[1950]: Activating service name='ca.desrt.dconf'
Dec 01 13:19:35 Gandalf dbus-daemon[1950]: Successfully activated service 'ca.desrt.dconf'
Dec 01 13:19:36 Gandalf ksmserver[2052]: Qt: Session management error: networkIdsList argument is NULL
Dec 01 13:19:36 Gandalf ksmserver[2052]: Configuring Lock Action
Dec 01 13:19:37 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/baloo_file.desktop" ("/usr/bin/baloo_file")
Dec 01 13:19:37 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/krunner.desktop" ("/usr/bin/krunner")
Dec 01 13:19:37 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/org.kde.plasmashell.desktop" ("/usr/bin/plasmashell")
Dec 01 13:19:37 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/pam_kwallet_init.desktop" ("/lib64/libexec/pam_kwallet_init")
Dec 01 13:19:37 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/polkit-kde-authentication-agent-1.desktop" ("/usr/lib64/libexec/polkit-kde-authentication-agent-1")
Dec 01 13:19:37 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/xembedsniproxy.desktop" ("/usr/bin/xembedsniproxy")
Dec 01 13:19:37 Gandalf ksmserver[2052]: Session path: "/org/freedesktop/login1/session/_32"
Dec 01 13:19:37 Gandalf polkit-kde-authentication-agent-1[2071]: New PolkitAgentListener  0x555599533680
Dec 01 13:19:37 Gandalf polkit-kde-authentication-agent-1[2071]: Adding new listener  PolkitQt1::Agent::Listener(0x7ff218013c40) for  0x555599533680
Dec 01 13:19:37 Gandalf polkit-kde-authentication-agent-1[2071]: Listener online
Dec 01 13:19:37 Gandalf polkitd[1290]: Registered Authentication Agent for unix-session:2 (system bus name :1.27 [/usr/lib64/libexec/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Dec 01 13:19:37 Gandalf polkit-kde-authentication-agent-1[2071]: Authentication agent result: true
Dec 01 13:19:37 Gandalf kdeinit5[1983]: Initializing  "kcm_kgamma" :  "kcminit_kgamma"
Dec 01 13:19:37 Gandalf kdeinit5[1983]: Initializing  "kded_touchpad" :  "kcminit_touchpad"
Dec 01 13:19:37 Gandalf kdeinit5[1983]: kcm_touchpad: Using X11 backend
Dec 01 13:19:38 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/gmenudbusmenuproxy.desktop" ("/usr/bin/gmenudbusmenuproxy")
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore1\" - conversion of \"841,841,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore2\" - conversion of \"841,841,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore3\" - conversion of \"841,841,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore4\" - conversion of \"841,841,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore5\" - conversion of \"841,841,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore6\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore7\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore8\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore9\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf kwin_x11[2057]: "\"fsrestore10\" - conversion of \"0,0,0,0\" to QRect failed"
Dec 01 13:19:38 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/pulseaudio.desktop" ("/usr/bin/start-pulseaudio-x11")
Dec 01 13:19:38 Gandalf ksmserver[2052]: org.kde.kf5.ksmserver: Starting autostart service  "/etc/xdg/autostart/restore_kmix_volumes.desktop" ("/usr/bin/kmixctrl", "--restore")
Dec 01 13:19:39 Gandalf kwin_x11[2057]: kwin_core: Compositing is not possible
Dec 01 13:19:40 Gandalf dbus[1161]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
Dec 01 13:19:40 Gandalf systemd[1]: Starting RealtimeKit Scheduling Policy Service...
[b]<snippage>[/b]
Dec 01 13:19:45 Gandalf kmix[2228]:
Dec 01 13:19:45 Gandalf kscreen_backend_launcher[2239]: kscreen.xrandr: Connected output 87 to CRTC 79
Dec 01 13:19:45 Gandalf kscreen_backend_launcher[2239]: kscreen.xrandr: Connected output 88 to CRTC 80
Dec 01 13:19:45 Gandalf kscreen_backend_launcher[2239]: kscreen.xcb.helper: Detected XRandR 1.6
Dec 01 13:19:45 Gandalf kscreen_backend_launcher[2239]: kscreen.xcb.helper: Event Base:  88
Dec 01 13:19:45 Gandalf kscreen_backend_launcher[2239]: kscreen.xcb.helper: Event Error:  145
Dec 01 13:19:48 Gandalf pulseaudio[2115]: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
Dec 01 13:19:48 Gandalf rtkit-daemon[2116]: Successfully made thread 2283 of process 2283 (/usr/bin/pulseaudio) owned by '1000' high priority at nice level -11.
Dec 01 13:19:48 Gandalf rtkit-daemon[2116]: Supervising 4 threads of 2 processes of 1 users.
Dec 01 13:19:52 Gandalf pulseaudio[2283]: [pulseaudio] pid.c: Daemon already running.
Dec 01 13:19:53 Gandalf dbus-daemon[1950]: Activating service name='org.freedesktop.Notifications'
Dec 01 13:19:53 Gandalf dbus-daemon[1950]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Dec 01 13:19:53 Gandalf dbus-daemon[1950]: Successfully activated service 'org.gtk.vfs.Daemon'
Dec 01 13:19:53 Gandalf notification-da[2303]: (for origin information, set GTK_DEBUG): failed to retrieve property 'gtk-toolbar-style' of type 'GtkToolbarStyle' from rc file value "((GString*) 0x559855894b80)" of type 'GtkToolbarStyle'
Dec 01 13:19:53 Gandalf dbus-daemon[1950]: Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service'
Dec 01 13:19:53 Gandalf dbus-daemon[1950]: Successfully activated service 'org.a11y.Bus'
Dec 01 13:19:53 Gandalf systemd[1885]: Starting Virtual filesystem service...
<snippage>
Subsequent to this, I eventually am able to login.
I hope this is helpful.
Thank you in advance.
VolvoBirkenstock
Post by VolvoBirkenstock » Mon Dec 03, 2018 2:49
Hello again.
This paragraph discusses my laptop, which I had previously thought was fixed by manipulations in previous posts in this thread. When I attempted to upgrade my laptop yesterday, I found that I had no network connections; no LAN and no Wireless. I tried to figure out root cause, but eventually gave up and performed an LFC. I now have a fully functional laptop.
Switching back to discussing the desktop now. I am considering performing an LFC. It will be extremely time-consuming for reasons previously posted. I will consider starting that process a week from now, when I have a little more time available.
Thank you very much for your patience.
Post by sabayonino » Mon Dec 03, 2018 12:58
I had the same problem after systemd upgrade on my sabayon-spin but non for all my installation
You can try to see if old systemd tbz2 package is still in your harddrive .
Downloaded packages are stored in /var/lib/entropy/ packages/packages/amd64/5 directory
If you don't have clenup the entropy cache , systemd-233.x should be placed inside sys-apps subdirectory.
something like : sys-apps:systemd-233.x.<package-hash>.tbz2
you can try to install systemd standalone package typing the full pacth of the package
Locate the package name and path and install
# equo i /var/lib/entropy/client/package/../../sys-apps/sys-apps:systemd-233.x.<package-hash>.tbz2
I fixed my testing image
Usually I perform a backup of installed packages see
equo pkg quickpkg -h
So I've restored the old systemd package.
VolvoBirkenstock
Post by VolvoBirkenstock » Tue Dec 04, 2018 4:37
THANK YOU, sabayonino.
I did exactly as you instructed and reinstalled version 233. All is well after reboot. I am marking this as "Solved".
For added bonus, you taught me two more equo manipulation of which I was unaware.
THANK YOU!!!
Re: [SOLVED] Auto-logout after weekly update
Post by sabayonino » Tue Dec 04, 2018 12:46
Systemd update (systemd 239.x ) still have some issue . My sabayon spin shows some dbus error and can't connect to the Networkmanager and I can't login in.
Other insatllations was fully upgraded without any errors .
Pay attention : do not run
# equo cleanup
mv/copy systemd-233.tbz2 or create a tbz . You can mask systemd-239
# equo mask "=sys-apps/systemd-239-r2"
and backup old version
# mkdir -p /root/entropy/sys-apps
# equo pkg quickpkg --savedir /root/entropy  sys-apps/systemd
category sys-apps must be exists , if not , you must create it .
Post by sabayonino » Tue Dec 04, 2018 12:50
THANK YOU!!!
I wrote an mini-howto how to backup entropy database and restore it and create an atom backup of some/all packages
https://wiki.sabayon.org/index.php?titl ... opy_backup
I can't translate to english 'cause the wiki can't be edited anymore for some wiki bug
VolvoBirkenstock
Re: Auto-logout after weekly update [Solved]
Post by VolvoBirkenstock » Sat Dec 08, 2018 4:08
Hi, sabayonino.
When I try to execute:
$ su
$ equo mask "=sys-apps/systemd-239-r2"
I see the following result:
╠  ## [M] =sys-apps/systemd-239-r2
╠     -> sys-apps/systemd-239-r2
☛ !!! Warning: =sys-apps/systemd-239-r2 action not executed.
╠ Have a nice day.
Why is it failing to work?
Thank you very much in advance.
Post by sabayonino » Sat Dec 08, 2018 11:03
package.mask file
# cp -a /etc/entropy/packages/package.mask.example /etc/entropy/packages/package.mask
VolvoBirkenstock
Post by VolvoBirkenstock » Sat Dec 08, 2018 23:29
Yet again, thank you, sabayonino.
manifesto
Post by manifesto » Mon Dec 10, 2018 7:25
Thanks to joost for the tip. It fixes the upgrade issue I had.
(My laptop has been installed in 2013).
