Where is the Sabayon tarball to install manually? [Solved]
linuxfluesterer
Post by linuxfluesterer » Wed Nov 07, 2018 13:04
Hallo guys.
A friend of mine needs to install a fresh Sabayon on his new pc box. But he is not really happy with the Calamares? installer especially when it comes to section 'Partitioning'
I have found a (German) thread about the same issue, that the involved user has the same trouble with this installer. But then he said, that Sabayon could be downloaded as a tarball, which is possible to be installed (unpacked?) into a mounted, empty partition.
I would recommend my friend to do the same.
So, here my question: Where, pls., can I find and download such a mentioned Sabayon tarball? On the download site of Sabayon I haven't found such an entry.
Thank you very much in advance.
Re: Where is the Sabayon tarball to install manually?
Post by sabayonino » Wed Nov 07, 2018 13:12
Here you can find a tarball
http://na.mirror.garr.it/mirrors/sabayo ... daily.html
(check for other mirror if needed)
Tarball is like a stage3 for gentoo.
Bootloader,desktop environment ,new user and other stuffs must be install/configured manually chrooting inside the extracted tarball !
linuxfluesterer
Post by linuxfluesterer » Wed Nov 07, 2018 14:35
Thank you, Sabayonino. So, what would you recommend to install Plasma desktop in addition too?
I'm assuming plasma-meta and some more packages, I'm not sure, I will necessarily need also, if not already included in plasma-meta.
Re: Where is the Sabayon tarball to install manually? [Solved]
Post by sabayonino » Tue Nov 27, 2018 18:15
You can start to install the meta-package(s) and enable the basic services and then install the extra packages you need
