Lightdm-settings issue [Solved]
andreios
Post by andreios » Sun Oct 28, 2018 14:03
The Sabayon Daily XFCE from Oct. 26th worked for me. Only one issue after Installation:
lightdm-settings
  File "/usr/bin/lightdm-settings", line 3, in <module>
    import xapp.os
ImportError: No module named 'xapp'
Somebody know how to fix this?
Don't know if next Daily ISO would work but ISO 27th boots but installer crashes.
Re: Lightdm-settings issue
Post by sabayonino » Sun Oct 28, 2018 17:11
Topic splitted.
Please one topic per issue
andreios
Post by andreios » Wed Oct 31, 2018 18:50
Thx.
Must be a python issue. But couldn't find much with google. dev-python/xapp-1.0.1-r2 is installed.
Post by sabayonino » Thu Nov 01, 2018 9:33
Could be python.
dev-lang/python:3.6 was updated (switched from py:3.5)
Maybe some packages should be recompiled with new paython release to fix some broken links.
if dev-lang/python:3,5 is installed you can switch to this
# eselect python list && eselect python set <choose the py:3.5 target>
Anyway ,c an you file a bug please ?
eselect python list
Available Python interpreters, in order of preference:
  [1]   python2.7
  [2]   python3.5 (uninstalled)
  [3]   python3.4 (uninstalled)
  [4]   python3.4 (uninstalled)
  [5]   python3.6 (fallback)
andreios
Post by andreios » Sat Nov 03, 2018 1:04
Today it just works. I've just updated daily.
(lightdm-settings: The GTK Theme and Icon Theme was not set. Which caused bad readability for the desktop manger selection.)
eselect python list        [1:04:48]
  [1]   python2.7
  [2]   python3.6
  [3]   python3.5
