Kernels are not longer showing up Rigo
themouseNZ
Post by themouseNZ » Tue Oct 09, 2018 23:48
I have been using Sabayon-KDE for several months now and it has become by go-to Distro out of all of them. I have found it to be a very smooth and stable experience. Several updates ago the 'Show Available installable Kernels' suddenly had no listings at all and the 'Show Available Long-Term-Stable kernels' was empty also. Now all I have is 'Linux Binary 0' and 'Linux Binary LTS 0' under the Available installable kernels and 'Linux Binary LTS 0' under the LTS kernel menu. What is the best way of installing kernels at the moment and any idea when this will be fixed? I tried to install 4.18 from the command line but was not very successful. I also have a new machine (HP x360 Envy with the AMD ryzen) and I believe it will need the 4.19 kernel when it becomes available as its not usable on Sabayon at the moment. Thanks
Re: Kernels are not longer showing up Rigo
Post by Fitzcarraldo » Wed Oct 10, 2018 2:20
I don't use Rigo, so can't advise you about that, but see the following blog post for how to install kernel images properly in Sabayon Linux: https://fitzcarraldoblog.wordpress.com/ ... yon-linux/
themouseNZ
Post by themouseNZ » Thu Oct 11, 2018 1:49
Thanks that worked great (much better to follow than the wiki page). It would be nice if Rigo worked again thou. Hopefully a future update will bring that functionality back.
svantoviit
Post by svantoviit » Wed Oct 17, 2018 8:04
Reported the same or similar already in the past: Bug 5104 missing keywords for kernels.
I have noticed a new package:
$ equo s -vq lts
virtual/linux-binary-lts-0
So maybe the functionality is managed differently now.
themouseNZ
Post by themouseNZ » Wed Oct 17, 2018 19:58
Maybe the devs are preparing for a change of some kind. Will wait and see, now at least I can install a new kernel and make it work so its not so bad.
Post by albfneto » Fri Oct 19, 2018 2:30
In my system, fully upgraded, today, 10/18/2018, kernel 4.18:
viewtopic.php?f=57&t=34052&start=10
in RIGO, i see only the virtual kernels:
bu if you want to see all the available kernels, you may search in RIGO, using the keyword "linux-sabayon". You will see the old kernels 4.4. and 4.9, the 4.14, LTS, "normal" kernel and the new 4.18.13 kernel.
commands, for example,
$ equo s linux-sabayon
show all kernels. Example in my system:
http://uploaddeimagens.com.br/imagens/novosquer-png
the regular LTS kernel is 4.14, bu i'm using the 4.18.13
In Sabayon, mainly i use commands, but sometimes and for tests, i use RIGO also.
