Latest Kernels and dracut issues
Post by sabayonino » Tue Sep 18, 2018 12:43
From 4.14.68 kernel and later boot fails. (4.16, 4.18... also )
Dracut seems to refuse to load/save many modules when starting to regenerate the initramfs.
I can't login.
Rescue Mode fails also.
Back to 4.14.67 (from my previous backup)
Now I'm updating KDE but not the kernel and its related dependencies.
(net-misc/lldpad & C. removed)
Re: Sabayon does not start, llptool
Post by sabayonino » Tue Sep 18, 2018 18:30
Installing 4.14.{68,69} kernels I get this
and this
And booting with 4.18.7 ,I get this
and I can't do anything.
What is /sysroot mountpoint ?
My system is stored to /dev/sda3 (/) ; /dev/sda1 (/boot)
/dev/sda3: UUID="19ca32e8-5845-43b3-8563-1781bd9573de" TYPE="ext4" PARTUUID="711b8136-03"
/dev/sda1: UUID="f2cd3511-1f3c-4cb6-a4a5-946d58e186c3" TYPE="ext4" PARTUUID="711b8136-01"
/dev/sda2: UUID="cd934830-bc67-4a55-be25-b3a423af8ec5" TYPE="swap" PARTUUID="711b8136-02"
Post by joost » Tue Sep 18, 2018 19:32
Can you please open a new topic. This is a totally different issue. (split off this)
Re: Latest Kernels and dracut issues
Post by sabayonino » Tue Sep 18, 2018 19:51
@Joost : Done
svantoviit
Post by svantoviit » Fri Sep 21, 2018 21:08
Got into the same. Sabayon won't boot. lldptool boot loop or when I'm lucky, dracut debug shell.
lldpad and fcoe-utils not installed. Intel graphics. sabayon-weekly, revision 3832
Managed chrooot, tried reinstalling kernel (4.14.68, 4.18.7) but getting error:
dracut-install: ERROR: installing '/etc/idmapd.conf'
dracut: FAILED ...
Edit: After reboot and some waiting dracut complains that it couldn't boot, lv_root does not exist and I am dropped into debug shell
How to fix?
Post by joost » Fri Sep 21, 2018 22:34
on the dracut shell you should be able to type in "exit" and the system loads. (not 100% sure)
Anyway.
Today we bumped all the kernels in main repo and we think we resolved all the problems with bad modules being loaded and the blacklist being ignored.
So please update and test.
(if you are on weekly repo you should not have dracut enabled kernels yet, we never pushed weekly with that)
Post by sabayonino » Sun Sep 23, 2018 14:45
Latest updates fix all kernel issues. (kernel 4.14.71 on sabayon-weekly repo)
Tnx !
svantoviit
Post by svantoviit » Mon Sep 24, 2018 20:46
No, after exit I was dropped into debug shell again.
Yes, updating to sys-kernel/linux-sabayon-4.18.9 helps and I'm able to boot again. Thank you, joost!
But still got into this issues.
# equo st
╠ # 1 Sabayon Linux Official Repository
╠     Repository name: sabayon-weekly
╠     Revision: 3840
