No icons when opening thunar [Solved]
multios
Post by multios » Wed Aug 22, 2018 22:31
I am running Sabayon Linux amd64 18.09. Two days ago, I ran equo update and equo upgrade to upgrade my system.
Today, when I opened thunar, no icons were shown for any file name or directory name. Just text.
I checked other sub-directories and no icons showed there either.
I also checked Thunar preferences to make sure there wasn't anything checked for just text, then I moved my .config/Thunar directory into different location and restarted Thunar. Still no icons.
At a loss what to try next.
Any help appreciated
Mike
Re: No icons when opening thunar
Post by sabayonino » Thu Aug 23, 2018 12:01
try to change the icon set
gnome-icon-theme was removed to the entropy store
after your upgrade , entropy asked to you to remove some packages (manually or automatically )
multios
Post by multios » Thu Aug 23, 2018 18:45
Thank you sabayonino, that took care of the problem.
