Extract tar file virtual:mysql inside of tbz2 package. How?
Learner
Post by Learner » Sun Aug 19, 2018 20:30
How do I extract the tar file inside virtual:mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tbz2 package?
I need to extract virtual_mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tar that is inside of:
I extracted virtual:mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tbz2
So please do not tell me how to extract a tbz2 file
virtual:mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tar
is the file to be extracted
Please extract virtual:mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tar
and let me know how you did it. Thank you very very much!
Please do not assume a certain method(s) of extracting a typical tar will work. Thanks again!
The Download Link is:
mirror1.mirror.garr.it/mirrors/sabayonlinux/entropy/standard/sabayonlinux.org/packages/amd64/5/virtual/virtual:mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tbz2
Learner
Tape archive = application/x-tar = .tar
Post by Learner » Sun Aug 19, 2018 21:26
Tar archive format is used on Unix/POSIX systems
Generally used in conjunction with compressors gzip, bzip2, compress or xz to create .tar.gz, .tar.bz2, .tar.Z or tar.xz files
Re: Extract tar file virtual:mysql inside of tbz2 package. How?
Post by sabayonino » Mon Aug 20, 2018 0:07
if you need to install virtual/virtual:mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tbz2
just run
# equo i /your-path/virtual:mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tbz2
if you need to extract its content
1 - convert to virtual:mysql package to SPM package
# equo pkg deflate <your-entropy-package.tbz2>
Package will be convert into /var/tmp/entropy directory
2 - Now you can extranct the package contents into "your-path"
# tar -xvpaf /var/tmp/entropy/<your-package.tbz2> -C /your-path
see
# equo --help
and
# equo pkg --help
Learner
Post by Learner » Mon Aug 27, 2018 16:49
Gave me ~ this in /var/tmp/entropy/ =
/var/tmp/entropy/virtual_mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tbz2
# tar -xvpaf /var/tmp/entropy/virtual_mysql-5.6-r12.e1d487a5fad61eb7b439991dcfdfd531b1a2fba5~0.tbz2 -C /path to directory
Gave me ~ this message with nothing in "/path to directory" =
bzip2: (stdin): trailing garbage after EOF ignored
Learner
Post by Learner » Mon Aug 27, 2018 16:54
I know how to extract
Learner
Post by Learner » Mon Aug 27, 2018 16:56
This is the file to be extracted
Learner
Post by Learner » Mon Aug 27, 2018 16:57
Is the file inside of
Learner
Post by Learner » Mon Aug 27, 2018 17:07
It is recognized as =
Tar archive
application/x-tar
Learner
Post by Learner » Mon Aug 27, 2018 17:11
The file itself is recognized as a =
STL 3D model (binary)
model/x.stl-binary
Learner
Post by Learner » Mon Aug 27, 2018 17:20
:roll:
