[Question] broken download link
wkp13
Post by wkp13 » Sat Aug 18, 2018 15:23
Hey, I'm new here.
is anyone having this problem the website download link is broken? from this link https://www.sabayon.org/desktop/
I can't download the installation file. the only way is using mirror link but from where I live here in the sucks internet connection world, that's impossible.
and the mirror links from my country isn't working either. I'm living in Indonesia by the way.
is this happens globally?
sorry guys for this total wrong topic I created.
regards
Re: [Question] broken download link
Post by sabayonino » Sat Aug 18, 2018 16:08
For me all download links work
wkp13
Post by wkp13 » Sun Aug 19, 2018 13:57
okay thanks for the information, going to check on that.
i wish the moderator read it and go check on that download link.
Post by Stupot » Sun Aug 19, 2018 17:21
They all work for me too. I'm not sure what you're looking for out of the moderator (although there isn't really a moderator, there's a team of devs who support all things sabayon).
wkp13
Post by wkp13 » Thu Aug 23, 2018 14:23
They all work for me too. I'm not sure what you're looking for..........
thanks for the information guys, I solved this. I just used VPN and download from the US server, it's maybe developers in my country is inactive or something. for everyone who faces the same problem on download link just use VPN.
Post by sabayonino » Tue Nov 06, 2018 12:23
check for daily builds also
http://mirror3.mirror.garr.it/mirrors/s ... daily.html (or other mirror(s))
