Sky2 Module broken
vibrion
Sky2 Module broken
Post by vibrion » Tue Jul 10, 2018 18:06
After an upgrade to latest kernel sky2 module is having problems:
sky2 0000:06:00.0 eth0: tx timeout
sky2 0000:06:00.0 eth0: transmit ring 9 .. 14 report=9 done=9
sky2 0000:06:00.0 eth0: Link is up at 100 Mbps, half duplex, flow control both
This is the dump of the kernel
[36588.479312] NETDEV WATCHDOG: eth0 (sky2): transmit queue 0 timed out
[36588.479344] WARNING: CPU: 3 PID: 0 at net/sched/sch_generic.c:473 dev_watchdog+0x1eb/0x1f0
[36588.479465] Modules linked in: sky2 ctr ccm rfcomm bnep brcmsmac cordic brcmutil b43 uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 btusb btrtl btbcm btintel bluetooth mac80211 videobuf2_common videodev media gpio_ich intel_powerclamp joydev iTCO_wdt cfg80211 ssb iTCO_vendor_support mmc_core ecdh_generic samsung_laptop coretemp kvm_intel kvm snd_hda_codec_hdmi psmouse snd_hda_codec_realtek snd_hda_codec_generic input_leds irqbypass crc32c_intel i2c_i801 serio_raw snd_hda_intel lpc_ich pcspkr intel_agp bcma intel_ips shpchp sch_fq_codel vboxnetflt(O) vboxnetadp(O) vboxdrv(O) ipv6 crc_ccitt dm_thin_pool dm_persistent_data dm_bio_prison dm_service_time dm_round_robin dm_queue_length dm_multipath dm_log_userspace dm_flakey dm_delay virtio_pci virtio_scsi virtio_blk virtio_console virtio_balloon
[36588.479504] xts aes_x86_64 sha512_generic sha256_generic iscsi_tcp libiscsi_tcp ixgb ixgbe samsung_sxgbe tulip cxgb cxgb4 vxge bonding vxlan ip6_udp_tunnel udp_tunnel macvlan vmxnet3 virtio_net virtio_ring virtio tg3 r8169 pcnet32 mii igb dca e1000 atl1c fuse overlay xfs nfs lockd grace sunrpc jfs reiserfs ext4 jbd2 fscrypto ext2 mbcache firewire_core sl811_hcd xhci_plat_hcd xhci_pci xhci_hcd ohci_pci ohci_hcd uhci_hcd lpfc nvmet_fc nvmet configfs qla2xxx nvme_fc nvme_fabrics sx8 imm parport pata_pcmcia pcmcia hid_generic i915 snd_hda_codec snd_hda_core snd_hwdep ehci_pci snd_pcm drm_kms_helper snd_timer ehci_hcd snd drm fb_sys_fops syscopyarea intel_gtt sysfillrect sysimgblt i2c_algo_bit agpgart [last unloaded: sky2]
[36588.479552] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G O 4.17.0-sabayon #1
[36588.479553] Hardware name: SAMSUNG ELECTRONICS CO., LTD. R430/R480/R440 /R430/R480/R440 , BIOS 05UZ.M013.20100525.XW 05/25/2010
[36588.479555] RIP: 0010:dev_watchdog+0x1eb/0x1f0
[36588.479557] RSP: 0018:ffff880117d83eb8 EFLAGS: 00010296
[36588.479558] RAX: 0000000000000038 RBX: 0000000000000000 RCX: 0000000000000000
[36588.479559] RDX: 0000000000040400 RSI: 00000000000000f6 RDI: 0000000000000300
[36588.479560] RBP: ffff8801018fc478 R08: 0000000000000001 R09: 00000000000006dd
[36588.479562] R10: 0000000000000282 R11: 0000000000000000 R12: ffff8801018fc000
[36588.479563] R13: 0000000000000003 R14: 0000000000000282 R15: ffffffff82605100
[36588.479564] FS: 0000000000000000(0000) GS:ffff880117d80000(0000) knlGS:0000000000000000
[36588.479565] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[36588.479567] CR2: 00007f8032a571a0 CR3: 000000000260a006 CR4: 00000000000206e0
[36588.479568] Call Trace:
[36588.479571] <IRQ>
[36588.479573] ? qdisc_reset+0xd0/0xd0
[36588.479577] call_timer_fn+0x16/0x80
[36588.479579] expire_timers+0x7a/0x90
[36588.479581] run_timer_softirq+0x6e/0x130
[36588.479584] ? __hrtimer_run_queues+0xf7/0x180
[36588.479586] ? ktime_get+0x36/0x90
[36588.479589] ? lapic_next_event+0x11/0x20
[36588.479592] __do_softirq+0xe1/0x1e9
[36588.479597] irq_exit+0xa9/0xb0
[36588.479599] smp_apic_timer_interrupt+0x4d/0x80
[36588.479601] apic_timer_interrupt+0xf/0x20
[36588.479602] </IRQ>
[36588.479605] RIP: 0010:cpuidle_enter_state+0x11d/0x210
[36588.479607] RSP: 0018:ffffc900006abea8 EFLAGS: 00000286 ORIG_RAX: ffffffffffffff13
[36588.479608] RAX: ffff880117da15c0 RBX: 0000000000000004 RCX: 000000000000001f
[36588.479609] RDX: 00002146eb4f6f43 RSI: 0000000000020dc0 RDI: 0000000000000000
[36588.479611] RBP: ffff880117da9918 R08: 00000511290e30d4 R09: 0000000000000018
[36588.479612] R10: ffffc900006abe88 R11: 00000000000003b1 R12: 00002146eb4f6f43
[36588.479613] R13: 00002146eae42869 R14: 0000000000000004 R15: ffffffff8266f520
[36588.479615] ? cpuidle_enter_state+0x119/0x210
[36588.479618] do_idle+0x1cf/0x230
[36588.479620] cpu_startup_entry+0x5a/0x60
[36588.479621] start_secondary+0x176/0x1b0
[36588.479623] secondary_startup_64+0xa5/0xb0
[36588.479625] Code: 50 78 48 63 4d e8 eb 97 4c 89 e7 c6 05 3e f1 d3 00 01 e8 b9 8c fd ff 89 d9 48 89 c2 4c 89 e6 48 c7 c7 78 42 3a 82 e8 15 4e 6c ff <0f> 0b eb c6 90 48 c7 47 08 00 00 00 00 48 c7 07 00 00 00 00 0f
Booting with latest sysrescuecd pendrive sky2 works fine, so its not a hardware problem.
HELP! this is quite anoying, I should make a kernel downgrade??
Re: Sky2 Module broken
Post by sabayonino » Tue Jul 10, 2018 18:22
please try this :
zcat /proc/config.gz | grep SKY2
should be somethink like this :
CONFIG_SKY2=m
# CONFIG_SKY2_DEBUG is not set
and check if the module is loaded :
# lsmod | grep sky2
sky2                   65536  0
vibrion
Post by vibrion » Tue Jul 10, 2018 19:28
Its exactly as above (module loaded and compiled in kernel)
Post by joost » Tue Jul 10, 2018 19:46
What kernel version are you running?
You can always use the kernel-switcher tool to use a different kernel version.
https://wiki.sabayon.org/index.php?titl ... l_Switcher
Post by sabayonino » Tue Jul 10, 2018 20:56
@Joost He's running 4.17 kernel
from log above :
Post by joost » Tue Jul 10, 2018 21:02
Well we never forced to use that kernel, simply switch to a known to work kernel then.
vibrion
Post by vibrion » Tue Jul 10, 2018 21:30
Mmmm I know i can switch back to an older kernel. The question that remains is why i cannot use latest? On the other hand which kernel is distributed in the stable release now?
Thanks
Post by joost » Tue Jul 10, 2018 21:53
4.14
Post by sabayonino » Tue Jul 10, 2018 22:13
[OT]
@Joost
can the following command be trusted?
# equo s lts -qv
RIGO shows LTS kernels :
# equo s -qv virtual/linux-binary-lts
Sabayon LTS kernels
$ equo s lts -qv
sys-kernel/linux-sabayon-4.1.52
sys-kernel/linux-sabayon-4.14.53
sys-kernel/linux-sabayon-4.4.136
sys-kernel/linux-sabayon-4.9.111
[/OT]
vibrion
Post by vibrion » Wed Jul 11, 2018 17:35
Rolling back to 4.14.53....
