Molecule for making large ISO.
Post by albfneto » Fri Jun 29, 2018 19:19
i ask if it is possible to use Molecule for making an 8 giga large ISO, for burn in 8 giga DVD.
This is because i have in mind to make a Sabayon Remaster for Chemistry. A "Chemical Sabayon" for using installed or or as a Live DVD itself.
I'm a Chemist.
Re: Molecule for making large ISO.
Post by sabayonino » Fri Jun 29, 2018 20:04
Do you consider to boot from USB stick/disk ?
Post by albfneto » Fri Jun 29, 2018 20:58
The idea is to make an ISO for Chemists. They can be used the system installed, or in live pendrive, or even in a large bootable DVD. They choosed from their preference.
I will cite the Sabayon, and not change the name Sabayon Linux, since it will be a remaster, and not a new Distro.
Post by sabayonino » Fri Jun 29, 2018 21:15
I think the final ISO size depend on extra data you will put in
livecd.squash file should be compressed with default gzip algo
