[solved] Sabayon und nvidia-drivers
Allgemeine Gespräche hinsichtlich Sabayon Linux
ManBl
Re: [solved] Sabayon und nvidia-drivers
Post by ManBl » Thu Jun 21, 2018 6:47
Ich habe den Vorschlag mit
equo mask
in verschiedenen Sabayon-Installationen getestet.
Nur in der mit dem neuen Installer hat es geklappt,
in allen anderen wird es verweigert.
Daher habe ich es mit der mir von gentoo bekannten Methode versucht:
echo "=x11-drivers/nvidia-drivers-396.24" > /etc/portage/package.mask/package.mask
Das hat funktioniert. So ist es vielleicht am besten - jedenfalls für die alten
nach meiner Methode installierten Sabayons.
Gruß
Manfred
Post by sabayonino » Thu Jun 21, 2018 12:39
By default /etc/entropy/packages/package.{unmask,mask} doesn't exist.
echo "=..." > blah (or touch ... if you like this way)
is wrong
">" means "will override all previous contents".
redirect to add must be ">>"
Add new line to a file
echo "blah bla" >> file
Overwrite a file content
echo "bla bla" > file
with "=x11-nvidia-drivers/396.24" you'll masked only that version . New updates will not consider this old rule
">=x11-nvidia/396.24" will mask all next nvidia drivers releases . Your video card (nvidia 500 seriers) is supported up to <396.24 drivers version.
See /etc/entropy/packages/package.mask.example file
The first time you run "equo mask/unmask" this command doesn't work properly 'cause package.{unmask,mask} doesn't exist.
Creating this new file you can work with equo running
# equo mask/unmask
combinig all permitted comparations "= , =< , >= , < , > "
see
# equo mask/unmask --help
package.mask sample
# package.mask example file
# In this file you can specify dependencies, one per line, that you would like to mask.
# LINE CONSTRUCTION:
# <dependency to match>
# See examples below
# NOTE: for inline comments, please use "##" instead of "#"
# EXAMPLES:
# >=media-libs/foo-1.2.3
# media-libs/foo
# <media-libs/foo-1.2.3
# media-libs/foo:1
# >=media-libs/foo-1.2.3#2.6.23-sabayon-r1
# media-libs/foo::sabayon-repo
# :1 means package with SLOT="1"
# #2.6.23-sabayon-r1 means package with kernel tag = 2.6.23-sabayon-r1
ManBl
Post by ManBl » Thu Jun 21, 2018 18:51
Die daily-iso vom 20.06.2018 ist bereits von nvidia-drivers befreit.
Super!!!
Gruß
Manfred
ManBl
Post by ManBl » Sat Jul 07, 2018 7:31
Bitte um eine Ergänzung:
Nachdem die nvidia-Treiber aus den isos verbannt sind, komme ich mit keiner iso mehr direkt zum Desktop.
Grund: es fehlt ein Treiber, der keine Probleme bereitet: xf86-video-nouveau.
Läßt sich dieser Treiber nicht in eine iso einbauen, damit ich wenigstens nicht jedesmal erst bei schrecklich zitterndem Desktop
mit großer Mühe den Treiber installieren muß, um dann nach modprobe sofort auf den Desktop zu gelangen.
Das wäre - jedenfalls für ältere NVIDIA-Grafikkarten - eine denkbar gute Lösung.
Gruß
Manfred
P.S. ich habe das jetzt auch im englischen Forum gepostet.
ManBl
Post by ManBl » Sat Jul 07, 2018 12:08
Das Problem ist längst gelöst.
Hätte ich das eher gewußt, wär es leichter vonstatten gegangen.
Ich boote den USB-Stick mit Sabayon vom 06.07.2018,
lande auf dem schwarzen Bild mit cursor in der linken oberen Ecke.
Ich wechsle auf tty2, dort gebe ich schlicht ein
modprobe nouveau
und schon lande ich auf dem kde-plasma-Dekstop
und kann nun Sabayon installieren.
Gruß
Manfred
