How do I change run Level Sabayon 18.05 KDE
ItSaba
Post by ItSaba » Tue May 29, 2018 19:15
I'd like to change my run level from 3-5.
it says etc/inittab is no such file or directory
and it also says
vi is not a command when I try vi etc/inittab.
what do I do?
Re: How do I change run Level Sabayon 18.05 KDE
Post by Stupot » Tue May 29, 2018 20:58
You probably need to install vi before you can use vi.
ItSaba
Post by ItSaba » Tue May 29, 2018 21:05
How would I install vi? Also, the Inittab directory does not exist unless it comes with vi.
Post by Stupot » Wed May 30, 2018 5:41
I'd suggest trying to look how to install applications on Sabayon in general. There's a GUI app to try and make it very simple: https://wiki.sabayon.org/index.php?titl ... ge_Manager
