Plasma 5.12.4: All apps suddenly on one screen
linuxfluesterer
Post by linuxfluesterer » Tue Apr 24, 2018 14:05
Hallo guys.
I'm using Sabayon 18.04 with Plasma 5.12.4 and Kernel 4.15.17. A fresh install from last 10 days. Today I made an experience which happened to me with earlier versions of Plasma before.
I have a Dell monitor with 3440x1440 pixels, connected with HDMI 1.4 cable. I have six virtual screens, each one for different topics. What happened to me, I don't know the reason, is, that all the opened applications like firefox, kate, Vivaldi, System Settings, Dolphin and mpv player, and sometimes more, which all are on dedicated virtual screens before, were suddenly 'collected' onto one screen only. All applications are overlapping each other on this one surface. I still have my base control bar and a separate upper bar on top of screen.
But I can no more change to any application in the background nor to any virtual screen. All headlines of already opened applications are gone. I can still work in (some) applications in the foreground like typing or closing. But when I click a menu entry from menu line, the menu quickly appears and closes again by itself.
As I said, this behavior is known to me, but I have no idea, no solution to fix it. Honestly I don't really know how to describe this behavior for a search in Google.
Any idea? Thank you in advance.
Re: Plasma 5.12.4: All apps suddenly on one screen
Post by albfneto » Tue Apr 24, 2018 19:05
If i understood, you have six virtual "Areas" ( the default, regular is 4), is this? all the opened aplications are in the same screen, example in "area" 1...
is this?
linuxfluesterer
Post by linuxfluesterer » Wed Apr 25, 2018 15:16
albfneto wrote:If i understood, you have six virtual "Areas" ( the default, regular is 4), is this? all the opened aplications are in the same screen, example in "area" 1...
is this?
Correct. I have six virtual screens, each one serves a topic,
-infos and setting
- two browser windows side by side
-tv (kaffeine) and movies (mpv), by choice
-four dolphins two on top, two on bottom
-korganizer, full screen
-two konsoles (one for root, one for user)...
Exactly, it works nicely, when no 'crash'.
But in case of crash, all applications, dedicated to a separated virtual window, everything is 'stapled', impossible to change to a chosen application.
linuxfluesterer
Post by linuxfluesterer » Wed Jun 20, 2018 15:06
---Update---
I assume, I have found the responsible instance / program for this attitude, that all my spread applications of my Plasma ar 'imploded' to run on one surface only:
I had 'luck' to read a German message before it shaded out when this event of 'imploding' happened to me again today:
The German message was something about:
"Entschuldigung, aber KWin wurde unerwartet beendet..."
Translated in English it means that the KWin app was stopped unexpected.
So, what can I do, to prevent this attitude of KWin, pls? btw, in between I run Plasma 5.12.5.
