Authorization failed on locked screen [Solved]
linuxfluesterer
Post by linuxfluesterer » Mon Apr 16, 2018 15:02
Hallo guys.
I had to make a brand new installation on a new SSD. For this I used weekend's Daily-Build with latest Plasma elements, version 5.12.3 and Kernel 4.14. Installation went easy. But when I started to work with the installed Sabayon on SSD now, then I have a severe problem.
- First I boot into login screen, I can enter my password and the Plasma DE is ready to use
- After a while (5 minutes) the screen is locked, so far, so good
- I am asked for my password to unlock again, but after entering my password, I always receive the message:
The only way to my locked Plasma session ist the following
1. Change the terminal by pressing <Ctrl-Alt-F2>
2. Login as root
3. Enter the following command to find out which session is my Plasma:
loginctl list-session
SESSION UID  USER             SEAT             TTY
1       1000 linuxfluesterer  seat0
2          0 root             seat0            /dev/tty2
then I get a list with root and my own session (1000)
4. to unlock my session then I type:
loginctl unlog-session 1
(my session has id no. 2)
5. Then I have to press <Ctrl-Alt_F1>
and my Plasma session is unlocked again ... but, this is not the way to solve Authorization failed
So, what is wrong with the login manager, or which program ever handles my username and my password for locked sessions?
Thank you in advance.
Re: Authorization failed on locked screen
Post by Stupot » Tue Apr 17, 2018 19:36
linuxfluesterer
Post by linuxfluesterer » Tue Apr 17, 2018 22:11
Thank you very, very much, Stupot and to Andy (anomaly65) also. I have searched for the keywords "Authorization failed", so I did not receive this solution in forum's topics.
However, I don't know, what is the reason, why this directory:
/usr/lib64/libexec/kcheckpass
is not set with 's' by default after fresh install.
I will remember this solution and write it into a to do list for a future install.
Of course, I will mark this thread as [Solved] now.
linuxfluesterer
Re: Authorization failed on locked screen [Solved]
Post by linuxfluesterer » Thu Apr 19, 2018 14:59
************************* Update ********************************
After upgrading my system to Plasma 5.12.4 (and other components) today, the same problem appears. It is no more possible to login on a locked screen. Something in the upgrade must reset the flag for:
The solution is still to enter:
chmod u+s /usr/lib64/libexec/kcheckpass
as root again. Then it works to relogin.
Post by sabayonino » Fri Apr 20, 2018 16:32
linuxfluesterer wrote:Something in the upgrade must reset the flag for:
Simply the upgrade overwritten this libraries
as dirty fix you can add to the root .bashrc
# echo "chmod u+s /usr/lib64/libexec/kcheckpass" >> /root/.bashrc"
or to the root cronjob
# crontab -e
add
@reboot  chmod u+s /usr/lib64/libexec/kcheckpass
reinstall kde-plasma/kscreenlocker package and check if it works after reboot/and locker
[edit] I've no problem with kde screen locker :bom: . I can relogin to my kde session
linuxfluesterer
Post by linuxfluesterer » Tue Apr 24, 2018 13:58
Thanks Sabayonino.
Ok, I can make a separate task for crontab.
I decided to set the flag while booting, while I'm executing quite a 'local.d' adopted for systemd. I have several things to do before I want to have shown the login screen. But the way with put a line in root's .bashrc seems to be too late in case of fail.
Well, I need to think about, when I update again a part of Plasma.
Post by Stupot » Tue Sep 18, 2018 19:58
I still run into this problem with every KDE upgrade (I didn't do the cron job, assuming this was going to be fixed by upstream at some point).
Post by joost » Tue Sep 18, 2018 20:34
I never run into this problem myself. You guys use SDDM? I switched to lightdm some time ago. (KDE images are also shipping with that now)
Post by Stupot » Wed Sep 19, 2018 15:29
I am using SDDM on both of my systems. Although does the DM actually come into play for KDE's lock screen?
