No touchpad after install (acpi problem?)
denijane
Post by denijane » Fri Apr 06, 2018 21:25
Hi guys,
I made a new install on Asus FX503V. After some drama, it worked with the option acpi=off (Sabayon 17.0)
But I have no touchpad.
I don't see it in /var/log/Xorg.0.log even though I added it manually in /usr/share/X11/xorg.conf.d/
I know it works, because in bios, I have touchpad. So it's something else.
I tried adding:
i8042.noloop i8042.nomux i8042.nopnp i8042.reset
to GRUB, in pretty much all permutations, it doesn't help.
I tried
synclient TouchpadOff=0
it says:
"Couldn't find synaptics properties. No synaptics driver loaded?"
I think xinput doesn't detect it:
 xinput
⎡ Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ ITE Tech. Inc. ITE Device(8910)           id=7    [slave  pointer  (2)]
⎜   ↳ PIXART USB OPTICAL MOUSE                  id=10   [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ USB2.0 HD UVC WebCam                      id=6    [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=8    [slave  keyboard (3)]
    ↳ ITE Tech. Inc. ITE Device(8910)           id=9    [slave  keyboard (3)]
In dmesg I see as errors:
 ~ $ dmesg|grep error
[    7.197600] intel-lpss: probe of 0000:00:15.0 failed with error -22
[    7.363727] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[    7.363733] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[    7.364919] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[    7.364941] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[    7.981438] nvidia: probe of 0000:01:00.0 failed with error -1
[    8.002059] nvidia: probe of 0000:01:00.0 failed with error -1
[   49.117822] nvidia: probe of 0000:01:00.0 failed with error -1
also I get this suggestion to use pci=biosirq
   0.602097] pcieport 0000:00:01.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    0.602147] pcieport 0000:00:1c.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    0.602236] pcieport 0000:00:1c.5: can't find IRQ for PCI INT B; please try using pci=biosirq
[    0.602322] pcieport 0000:00:1c.6: can't find IRQ for PCI INT C; please try using pci=biosirq
[    0.602417] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[    0.602487] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.606237] mei_me 0000:00:16.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    0.610000] ahci 0000:00:17.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    1.297595] xhci_hcd 0000:00:14.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    1.305764] r8169 0000:02:00.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    1.314689] i915 0000:00:02.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    2.513750] input: ITE Tech. Inc. ITE Device(8910) as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:0B05:1869.0001/input/input2
[    4.254315] ehci-pci: EHCI PCI platform driver
[    4.278464] ohci-pci: OHCI PCI platform driver
[    7.197583] intel-lpss 0000:00:15.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    7.255431] snd_hda_intel 0000:00:1f.3: can't find IRQ for PCI INT A; please try using pci=biosirq
[    7.284032] i801_smbus 0000:00:1f.4: can't find IRQ for PCI INT A; please try using pci=biosirq
[    7.315721] rtsx_pci 0000:03:00.0: enabling device (0000 -> 0002)
[    7.315727] rtsx_pci 0000:03:00.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    7.315778] rtsx_pci 0000:03:00.0: rtsx_pci_acquire_irq: pcr->msi_en = 1, pci->irq = 26
[    7.360533] iwlwifi 0000:04:00.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[    7.415483] input: USB2.0 HD UVC WebCam as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/input/input4
[    7.949458] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input5
[    7.949534] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    7.949609] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    7.950022] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    7.981430] nvidia 0000:01:00.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[   36.323816] input: PIXART USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:093A:2510.0002/input/input10
I added pci=biosirq to grub but that didn't help and didn't remove the suggestion from dmesg.
Any ideas what's going on and how to solve the problem. I use my laptop for traveling, using an usb mouse is not a good option for me. So please, help...
P.S. Sound works, nvidia appears in lspci -v, webcam works, for the mics I still don't know.
Re: No touchpad after install (acpi problem?)
Post by sabayonino » Fri Apr 06, 2018 22:16
and check "touchpad" options in your system settings ? (GNOME,KDE ....)
denijane
Post by denijane » Fri Apr 06, 2018 23:06
System Settings says "No touchpad found". I'm with kde.
I'm also not sure the nvidia is running. Also nothing related to acpi doesn't work (obviously, since it's disabled in grub), but that means I can't turn off that horrible keyboard back-light. I'm so miserable...
