[ SOLVED ]gcc issue in all installation
orisystech
Re: gcc issue in all installation
Post by orisystech » Mon Feb 26, 2018 20:39
no, doesn't work. I uninstalled gcc 4.9, gcc 5.4 base-gcc 4.9, base-gcc 5.4 switch to 6.4 run . /etc/profile add python 3.5 in make.conf.... but nothing.
the error in config.log is:
x86_64-pc-linux-gnu-gcc: error: unrecognized command line option '-qversion'; did you mean '--version'?
cyklops66
Post by cyklops66 » Mon Feb 26, 2018 21:12
Yeap, i have exactly the same problem. Can't build some stuff anymore. I run - like on other gentoo machines - gcc-config, update profile and so on. No chance at this time.
orisystech
Post by orisystech » Mon Feb 26, 2018 21:31
for pacman I solved!
I switched binutils with binutils-config to the latest version.
Post by sabayonino » Mon Feb 26, 2018 21:32
aaaarghhhh ! Binutils !!! LOL
cyklops66
Re: [ SOLVED ]gcc issue in all installation
Post by cyklops66 » Mon Feb 26, 2018 22:56
Yeah, thank you. Strange thing, i had no files in /etc/env.d/binutils/. Installed .29 version binutils and now everything is fine.
Thank you very much.
