Tests of My New Sabayon, Installed [Solved]
Re: Tests of My New Sabayon, Installed [Solved]
Post by albfneto » Mon Feb 19, 2018 18:06
More tests... good!
My HP printer, DeskJet 2050, was detected auto when i try (for the first time) print a page.
It working. after, i installed and configured the HPLIP package.
Today, 02/19/2018, new upgrades. Many packages. working! Now, i'm using also the new kernel:
$ uname -a
Linux sabayon.local 4.15.0-sabayon #1 SMP Mon Feb 12 08:24:15 UTC 2018 x86_64 AMD FX(tm)-8120 Eight-Core Processor AuthenticAMD GNU/Linux
Sabayon installation working great
linuxfluesterer
Post by linuxfluesterer » Tue Feb 20, 2018 16:29
Hallo Alberto.
albfneto wrote:8, new upgrades. Many packages. working! Now, i'm using also the new kernel:
$ uname -a
How did you install the Kernel 4.15? Portage or Limbo (though you said before, you don't use Limbo). I haven't seen Kernel 4.15, when I updated my repo and then entered:
equo s linux-sabayon-4.15
╠  @@ Suche...
╠   Schlüsselwörter:  linux-sabayon-4.15
╠   Gefunden:         0 Einträge
I have some login troubles with Kernel 4.14.16, black login screen and my computer seems to 'hang' So for now I need to start in GRUB windows with Kernel 4.13.11.
p.s. I like your Cursor theme, but I wished it would be in 48 or 64 pixel size.
Post by sabayonino » Tue Feb 20, 2018 17:20
linux-sabayon-4.15 is available on sabayon-distro overlay
sys-kernel/linux-sabayon [1]
     Available versions:
     (3.10) (~)3.10.108^m
     (3.16) (~)3.16.40^m (~)3.16.41^m (~)3.16.42^m (~)3.16.43^m (~)3.16.44^m (~)3.16.45^m (~)3.16.46^m (~)3.16.47^m (~)3.16.48^m (~)3.16.49^m (~)3.16.50^m (~)3.16.51^m (~)3.16.52^m (~)3.16.53^m
     (3.18) (~)3.18.80^m (~)3.18.81^m (~)3.18.82^m (~)3.18.83^m (~)3.18.84^m (~)3.18.85^m (~)3.18.86^m (~)3.18.87^m (~)3.18.88^m (~)3.18.89^m (~)3.18.90^m (~)3.18.91^m (~)3.18.92^m (~)3.18.93^m (~)3.18.94^m
     (4.1)  (~)4.1.40^m (~)4.1.41^m (~)4.1.42^m (~)4.1.43^m (~)4.1.44^m (~)4.1.45^m (~)4.1.46^m (~)4.1.47^m (~)4.1.48^m (~)4.1.49^m
     (4.4)  (~)4.4.110^m (~)4.4.111^m (~)4.4.112^m (~)4.4.113^m (~)4.4.114^m (~)4.4.115^m
     (4.9)  (~)4.9.70^m (~)4.9.71^m (~)4.9.72^m (~)4.9.73^m (~)4.9.74^m (~)4.9.75^m (~)4.9.76^m (~)4.9.77^m (~)4.9.78^m (~)4.9.79^m (~)4.9.80^m
     (4.14) (~)4.14^m (~)4.14.1^m (~)4.14.2^m (~)4.14.3^m (~)4.14.4^m (~)4.14.5^m (~)4.14.6^m (~)4.14.7^m (~)4.14.8^m (~)4.14.9^m (~)4.14.10^m (~)4.14.11^m (~)4.14.12^m (~)4.14.12-r1^m (~)4.14.13^m (~)4.14.14^m (~)4.14.15^m (~)4.14.16^m (~)4.14.17^m (~)4.14.18^m
     (4.15) (~)4.15^m (~)4.15.1^m (~)4.15.2^m
       {btrfs build dmraid dracut iscsi luks lvm mdadm plymouth splash symlink}
     Installed versions:  4.14.16(4.14)^m(16:10:19 03/02/2018)(btrfs dmraid iscsi luks lvm mdadm plymouth symlink -build -dracut -splash)
     Homepage:            https://github.com/Sabayon/kernel
     Description:         Official Sabayon Linux Standard kernel image
[1] "sabayon-distro" /var/lib/layman/sabayon-distro
linuxfluesterer
Post by linuxfluesterer » Tue Feb 20, 2018 17:42
Thank you, Sabayonino.
I never worked with Sabayon-distro-overlay. And I don't think about to do this at this time. So, I will wait, until normal Sabayon repo will have the Kernel 4.15, which I hope, will fix my login issue (black screen and 'hanging'.
Ryuno-Ki
Post by Ryuno-Ki » Mon Feb 26, 2018 20:20
@Joost correct me if I'm wrong, but Kernel v4.15 is around the corner, isn't it? Or what is the roadmap? To my knowledge, we were about to stick to LTS kernels: https://www.sabayon.org/article/sabayon ... e-strategy
Post by Stupot » Tue Feb 27, 2018 19:20
Ryuno-Ki wrote:@Joost correct me if I'm wrong, but Kernel v4.15 is around the corner, isn't it? Or what is the roadmap? To my knowledge, we were about to stick to LTS kernels: https://www.sabayon.org/article/sabayon ... e-strategy
Are you talking about it just being available? Because it's been available for a while now: https://packages.sabayon.org/quicksearc ... 15&x=0&y=0
Since 4.15 isn't a LTS kernel, it won't be a part of the fresh install.
Post by albfneto » Wed Feb 28, 2018 20:24
i have in mind that i have the kernel 4.15 (from the limbo repo)
uname -a
sys-kernel/linux-sabayon-4.15.2 ramo: 5, [sabayonlinux.org]
╠          Disponível:   versão: 4.15.2 ~ tag: NoTag ~ revisão: 0
╠          Instalado:    versão: 4.15.2 ~ tag: NoTag ~ revisão: 0
╠          Slot:         4.15
╠          Homepage:     https://github.com/Sabayon/kernel
╠          Descrição:    Official Sabayon Linu
Actually, it is 4.15.2 and is easy to find even in the weekly repo:
https://packages.sabayon.org/show/linux ... 5,standard
It works in my system, but the 4.14 also worked.
MORE RESULTS OF MY TESTS AND USE. AFTER UPGRADES, NO MORE INTERNET ACESS.
The first small problem im my installation osf Sabayon. After the upgrades of yesterday.... No more network, no more internet. I dont filled a bug in bugzilla, since i'm not certain that is really a bug.
Interesting that was only in this Sabayon, because the problem not occurred in OpenSUSE and in my older Sabayon...in both, the net working
It is my comp. at the UNiversity, an wired conection, with DHCP.... i found that the problem was in DHCP.
Why? is because if i make again and used my old, antique conection protocol
(gateway and static DNS and IP, is no more used as default from 3 years ago)
With static IP, internet works! from this internet conection, i installed the package DHCPCD.... then , i disconnect and remove this "auxiliary" static IP conection.
i put the service dhcpcd,service, enabled in Systemd, and BINGO.... Network and Internet, again.
For people and/or developers:
Sumarizing.... Upgrades of the day 02/27/2018 had broken DHCP .....is this a Bug? Install the package "dhcpcd" and enable the dhcpcd.service in the systemd, solve the issue....
another issue, simple. Kwin effects no more working with the older Mesa package, but when mesa was upgraded, all is good.
Re: Tests of My New Sabayon, Installed [Reopened]
Post by albfneto » Tue May 08, 2018 17:39
I continue using this Sabayon and testing. Since the Sabayon is working very good., i will close the topic.
Post by albfneto » Sun Jul 15, 2018 0:39
I know, this is solved, bu this is a kind of info, good news, to developers and community....
I still continue testing and using this installation of Sabayon.
near a year installed...
Fully upgraded to Sabayon 18.11, working good and responsive!
Even I changed the kernel to 4.18.11.
10/07/2018, I upgraded my Sabayon!
This is my new image of Neofetch. My Neofetch is "colors changed" and translated to Brazilian Portuguese:
https://i.postimg.cc/DZBPn875/novoneofetch.png
Today, 11/29/2018, fully upgraded again. Working like a charm, including binutils and related.
Post by albfneto » Thu Jul 25, 2019 23:27
I still use Sabayon as my main Distro... Each Day.
It is developed more and more stable...
no more problems with kernel change, video drivers, old non boot issues.
I upgraded my Sabayon installations today, 07/25/2019.
I'm using also the latest kernel.
Congratulations again to the team. Sabayon is the best Linux Distro.
