Scummvm [Solved]
hdegaard
Scummvm [Solved]
Post by hdegaard » Mon Nov 27, 2017 22:18
Hi
I just used equo to install Scummvm, but it won't start. It's on a Lenovo T410 with Intel graphics, Sabayon KDE, kernel 4.13. What could be the problem?
Re: Scummvm
Post by Stupot » Tue Nov 28, 2017 5:39
Can you try and start it from the command line and see if it gives you any helpful output (or any output at all and paste it here)?
hdegaard
Re: Scummvm
Post by hdegaard » Tue Nov 28, 2017 9:58
Ok. this is what I get when I try to start from console:
[email protected] ~ $ scummvm
scummvm: symbol lookup error: scummvm: undefined symbol: SDL_free
Re: Scummvm
Post by sabayonino » Tue Nov 28, 2017 12:43
I'm not sure
but it can need of media-libs/libsdl package
is it installed on your system ?
# equo q installed media-libs/libsdl -qv
hdegaard
Re: Scummvm
Post by hdegaard » Tue Nov 28, 2017 20:47
I had this output:
[email protected] ~ $ equo q installed media-libs/libsdl -qv
media-libs/libsdl-1.2.15-r9
media-libs/libsdl-2.0.0_pre7001
media-libs/libsdl2-2.0.4
Re: Scummvm
Post by sabayonino » Sat Dec 02, 2017 13:42
I think this is related to SDL-<something> compiled libraries
I can't understand SDL error in your output
All Sabayon packages were rebuild with gcc-5.4.0 (migrated from 4.9.3 to 5.4.0). Could be this.
I suggest to open a new bug or ask to Scummvm forum :roll:
PS : Scummvm interface starts on my pc.
hdegaard
Re: Scummvm
Post by hdegaard » Sat Dec 02, 2017 14:03
Ok, thank you. I will try the Scummvm forum.
hdegaard
Re: Scummvm
Post by hdegaard » Sun Dec 03, 2017 13:51
Problem solved (sort of)
I installed Xfce desktop, and using that, Scummvm works :)
Re: Scummvm [Solved]
Post by sabayonino » Sun Dec 03, 2017 20:44
LOL
I'm curious about missing package(s) for scummvm :mrgreen:
