Is it possible to use Sabayon DevKit for making Gentoo pkg?
Post by albfneto » Tue Aug 29, 2017 22:09
I have expertise in making Gentoo packages (example using quickpkg) and also making the Sabayon Packages using equo pkg inflate and equo pgk quickpkg.
but always i used the normal installed environment.
Is it possible to use Docker-Sabayon DevKit:
https://wiki.sabayon.org/index.php?titl ... yon_Devkit
for also create "Gentoo" packages? Gentoo binaries, similar thar they are created using quickpkg?
