Is there to play games compatible with widows on linux??
A place where Linux Gamers can share their experience and help each other with Linux Games, native or emulated ;)
Markk786
Post by Markk786 » Sat Jul 29, 2017 1:43
RemediesRxSch
Tedel
Re: Is there to play games compatible with widows on linux??
Post by Tedel » Mon Sep 02, 2019 2:06
You have Steam and Wine to try that, and you can also install Windows in a virtual machine (WinXP should suffice for most games) and install the games there (although I suggest denying internet access to the virtual machine to avoid the never-ending annoyance of Microsoft's update service).
My 0.02.
Post by albfneto » Wed Sep 04, 2019 20:39
I have in mind that not all games... but you may try using Wine together with Playonlinux...
But if you can play many windows games, the best and easier solution is to use Double Boot, computer with both Windows and Sabayon
