06/14/2017, Daily Build, KDE. Installer Not Open[Solved]
Post by albfneto » Thu Jun 15, 2017 23:35
Testing. Install new Daily ISO:
Yesterday...May. 14, 2017.
i downloaded an KDE ISO, Daily Build, the newer this:
ftp://sabayon.c3sl.ufpr.br/sabayon/iso/ ... 64_KDE.iso
after burn on a DVD... it boots, working, but the Anaconda installer not open, neither window...
trying to open by command:
liveinst OR
# liveinst
Not works, not open the installer, and no error message ou messages wirh python errors and finally said that :
Selinux not found or active (so so this)
I tried again with other downloaded ISO, the same issue
I opened a new Bug about these issues:
https://bugs.sabayon.org/show_bug.cgi?id=5432
Re: 06/14/2017, Daily Build, KDE. Installer Not Open.
Post by sabayonino » Fri Jun 16, 2017 20:05
sys-libs/libselinux is missing.
from live , update repo and install sys-libs/libselinux
then run the installer
Post by albfneto » Thu Jun 22, 2017 22:45
Thanks, Sabayonino. Solved!
Post by albfneto » Fri Jul 07, 2017 0:27
According to a ne Brazilian user.... the libselinux is missing also in the newest Daily Builds.
koesherbacon
Post by koesherbacon » Thu Jul 13, 2017 6:18
I hadn't seen this thread before I posted that I had the same problem with all of the monthly July images as well as all the dailies from July 10th 2017.
 ⁓ Ev
Post by sabayonino » Thu Jul 13, 2017 11:18
Moved to "Installer Issues" forum. and removed [Solved] tag.
koesherbacon
Post by koesherbacon » Thu Jul 13, 2017 17:48
Thank you
 ⁓ Ev
Post by sabayonino » Mon Jul 17, 2017 19:15
Running KDE-dev/GNOME-dev 20170717 anaconda starts successfully :mrgreen:
linuxfluesterer
Post by linuxfluesterer » Wed Jul 19, 2017 15:17
I'm sorry to say that I still had the same problem with starting (opening) liveinst. I did the recommendations by Fitz:
sabayonino wrote:sys-libs/libselinux is missing.
When I started again, the liveinst didn't open either, The message was still the same:
selinux not found or active
But then I had an idea. I check for 'selinux' in Sabayon repo with:
equo s libselinux
and found this:
╠  @@ Suche...
╠      @@ Paket: sys-libs/libselinux-2.3-r2 Branch: 5, [sabayonlinux.org]
╠          Verfügbar:      Version: 2.3-r2 ~ tag: NoTag ~ Version: 0
╠          Installiert:    Version: Nicht installiert ~ tag: n/a ~ Version: n/a
╠          Slot:           0
╠          Homepage:       http://userspace.selinuxproject.org
╠          Beschreibung:   SELinux userland library
╠          Lizenz:         public-domain
╠      @@ Paket: sys-libs/libselinux-2.5 Branch: 5, [sabayonlinux.org]
╠          Verfügbar:      Version: 2.5 ~ tag: NoTag ~ Version: 0
╠          Installiert:     Version: 2.5. ~ tag: NoTag ~ Version: 0
╠          Slot:           0
╠          Homepage:       https://github.com/SELinuxProject/selinux/wiki
╠   Schlüsselwörter:  libselinux
╠   Gefunden:         2 Einträge
...which means, there are TWO libselinux version. So then I simply installed sys-libs/selinux-2.3-r2:
equo i sys-libs/libselinux-2.3-r2
... don't care about libselinux-2.5, and, voilà, see the wonder, now the liveinst window appears.
Hope, I could help those, who still have the same problem.
Post by sabayonino » Wed Jul 19, 2017 17:23
all is fixed in daily *-dev images
see https://bugs.sabayon.org/show_bug.cgi?id=5432#c10
I can confirm
so , libselinux for -dev images is "2.6"
