Samba shares available on some devices only [Solved]
msdobrescu
Post by msdobrescu » Sun Jun 11, 2017 20:08
I have done an update that came today, one single package, for OpenSSH.
Since then, I can't access the Samba shares anymore on one of my devices, the others requesting the password each time and working.
The device in question is a WD TV HD Live, up to date.
It says it cannot access the computer at all.
I have reset it, but no change.
Is anybody in the same trouble?
Thank you.
msdobrescu
Re: Samba shares available on some devices only
Post by msdobrescu » Tue Jun 13, 2017 18:24
Same thing for connecting remotely through OpenVPN client, on two machines.
It simply can't connect and no log message is provided.
Post by Fitzcarraldo » Sat Jun 17, 2017 13:21
I'm not sure, but if you don't have a line assigning 'ntlm auth' in /etc/samba/smb.conf, try adding:
ntlm auth = yes
and restart the samba service (or, alternatively, reboot).
Apparently the default in <samba-4.5 was 'yes' and in >=net-fs/samba-4.5 the default is 'no'.
Ref. Samba 4.5 tip[solved]
msdobrescu
Post by msdobrescu » Sat Jun 17, 2017 16:12
Thank you so much!
That solved it!
You're the man!
