Static IP Address [Solved]
Lazydog
Post by Lazydog » Sun Apr 30, 2017 3:25
I recently installed Sabayon on my desktop and I'm finding it impossible to figure out how to set a static IP Address.
What are the procedures for stetting a static IP Address? shystem is Sabayon Linux amd64 17.04
Thank you.
Regards
Robert
Re: Static IP Address
Post by albfneto » Sun Apr 30, 2017 3:59
In the University, i have Static IP.
Generally, the Network connection can be setted in the NetworkManager Client from your Graphical Environment.
But in many cases, prior, you should deactivate and remove the DHCP support....:
# sudo equo rm --configfiles --nodeps dhcp dhcpcd
then, configure "via" you graphical interface. Sometimes, for me, it was necessary to change the NetworkManager, substitute it by the WICD package.
Lazydog
Post by Lazydog » Sun Apr 30, 2017 21:49
Hello albfneto,
Thank you for the reply. I have found a way to do it that I like a whole lot better.
Here are the steps I've taken:
1. Edit the following file. If it doesn't exist then you should create it.
/etc/systemd/network/25-wired.network
Add the following to your or modify to match your system
[Match]
Name=enp0s31f6 <[i]*** This should be your interface that the network is connected to ***[/i]>
[Network]
Address=192.168.15.100/24 <[i]*** Your network IP Address ***[/i]>
Gateway=192.168.15.1
2. We need to stop NetwokManager and start systemd-networkd with the following:
systemctl stop NetworkManager
systemctl enable systemd-networkd
systemctl start systemd-networkd
3 Reboot
You will now have a static IP Address.
Regards
Robert
