Any LEGO design software available in Sabayon? [Solved]
msdobrescu
Post by msdobrescu » Tue Apr 18, 2017 9:00
Is there any Lego design software available in Sabayon?
At least, any working solution applied by anybody here?
Thank you.
Re: Any LEGO design software available in Sabayon?
Post by sabayonino » Tue Apr 18, 2017 11:31
Hi
In portage tree there is
kde-misc/konstruktor
     Available versions:  (4) (~)0.9_beta1
       {aqua test}
     Homepage:            http://konstruktor.influx.kr/
     Description:         LEGO CAD
you can try to request this package for sabayon entropy store
https://bugs.sabayon.org/
but its homepage isn't available : http://konstruktor.influx.kr/
msdobrescu
Post by msdobrescu » Tue Apr 18, 2017 11:40
Thanks, but the project seems dead.
Post by sabayonino » Tue Apr 18, 2017 12:03
msdobrescu wrote:Thanks, but the project seems dead.
I see :cry:
msdobrescu
Post by msdobrescu » Sat Jan 27, 2018 19:08
Hi, I could install LDCad, the linux package works well, but I have a LDD file that needs to be exported.
Is there a successful wine setup for LDD?
I could not make it run, I only get errors:
err:service:process_send_command service protocol error - failed to write pipe!
fixme:service:scmdatabase_autostart_services Auto-start service L"clr_optimization_v4.0.30319_32" failed to start: 1053
err:module:import_dll Library MSVCR120_CLR0400.dll (which is needed by L"C:\\windows\\Microsoft.NET\\Framework64\\v4.0.30319\\mscorsvw.exe") not found
err:module:import_dll Library mscoree.dll (which is needed by L"C:\\windows\\Microsoft.NET\\Framework64\\v4.0.30319\\mscorsvw.exe") not found
err:module:LdrInitializeThunk Main exe initialization for L"C:\\windows\\Microsoft.NET\\Framework64\\v4.0.30319\\mscorsvw.exe" failed, status c0000135
fixme:service:scmdatabase_autostart_services Auto-start service L"clr_optimization_v4.0.30319_64" failed to start: 1053
err:hid_report:process_hid_report Device reports coming in too fast, last report not read yet!
msdobrescu
Post by msdobrescu » Sun Sep 15, 2019 11:00
LDCad works fine, is an excellent tool. Also, BrickLink's Studio is OK under Wine for converting various LEGO CAD files.
