Cannot find ksnapshot
scanti81
Post by scanti81 » Sun Mar 05, 2017 21:42
I recently updated Sabayon. Unfortunately, I could not launch ksnapshot, I am sure it was there before. Even when I search it on Rigo, it is missing. Is there a way to make it work?
Thanks
Re: Cannot find ksnapshot
Post by Stupot » Sun Mar 05, 2017 22:35
ksnapshot was replaced in the kde suite by spectacle.
[email protected] ~  $ equo search spectacle
╠  @@ Searching...
╠      @@ Package: kde-apps/spectacle-16.12.2 branch: 5, [sabayonlinux.org]
╠          Available:     version: 16.12.2 ~ tag: NoTag ~ revision: 0
╠          Installed:     version: 16.12.2 ~ tag: NoTag ~ revision: 0
╠          Slot:          5
╠          Homepage:      https://www.kde.org/
╠          Description:   Screenshot capture utility
╠          License:       FDL-1.3 LGPL-2+
╠   Keywords:  spectacle
╠   Found:     1 entry
You might need to re-configure kde system settings to get the print screen shortcut working if it's not working out of the box for you.
See this arch forum post to do that: https://bbs.archlinux.org/viewtopic.php ... 0#p1589860
