equo crashing
dan.kasak
equo crashing
Post by dan.kasak » Thu Jan 12, 2017 1:57
Hi all. equo is crashing for me when it encounters rp-pppoe. This happens both when attempting to upgrade it ( via equo upgrade --ask ), and when attempting to remove it ( via equo remove rp-pppoe ).
So I'm stuck. Any ideas?
  File "/usr/bin/equo", line 15, in <module>
    main()
  File "/usr/lib/entropy/client/solo/main.py", line 332, in main
    exit_st = func(*func_args)
  File "/usr/lib/entropy/client/solo/commands/command.py", line 435, in _call_shared
    return func(client)
  File "/usr/lib/entropy/client/solo/commands/remove.py", line 149, in _remove
    packages)
  File "/usr/lib/entropy/client/solo/commands/remove.py", line 373, in _remove_action
    remove_config_files)
  File "/usr/lib/entropy/client/solo/commands/remove.py", line 195, in _execute_action
    exit_st = pkg.start()
  File "/usr/lib/entropy/lib/entropy/client/interfaces/package/actions/action.py", line 218, in start
    exit_st = self._run()
  File "/usr/lib/entropy/lib/entropy/client/interfaces/package/actions/remove.py", line 330, in _run
    exit_st = method()
  File "/usr/lib/entropy/lib/entropy/client/interfaces/package/actions/remove.py", line 159, in _remove_phase
    return self._remove_phase_unlocked(inst_repo)
  File "/usr/lib/entropy/lib/entropy/client/interfaces/package/actions/remove.py", line 212, in _remove_phase_unlocked
    preserved_mgr)
  File "/usr/lib/entropy/lib/entropy/client/interfaces/package/actions/_manage.py", line 688, in _remove_content_from_system
    sys_root)
  File "/usr/lib/entropy/lib/entropy/client/interfaces/package/actions/_manage.py", line 502, in _remove_content_from_system_loop
    do_allocation_check = False, do_quiet = True
  File "/usr/lib/entropy/lib/entropy/client/interfaces/package/actions/_manage.py", line 336, in _handle_config_protect
    protected = entropy.tools.istextfile(tofile)
  File "/usr/lib/entropy/lib/entropy/tools.py", line 1929, in istextfile
    r = istext(f.read(blocksize))
  File "/usr/lib64/python3.4/codecs.py", line 319, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa0 in position 40: invalid start byte
Re: equo crashing
Post by Fitzcarraldo » Sat Jan 14, 2017 13:45
Try tidying things up:
# equo conf update
# equo cleanup
# equo deptest
# equo libtest
# equo update
# equo upgrade
# equo conf update
# equo deptest
# equo libtest
