No Network Capability [Solved]
Stevo141
Post by Stevo141 » Tue Nov 22, 2016 3:17
I accidentally deleted NetworkManager in the hopes of using WICD which I couldn't get to work anyway! Now I'm stuff with no network capability at all! I want to get NM back. I believe there's a way to upload NM from the live CD but I don't know how to do it. Can someone provide assistance?
Thanks in advance for your help!!!
Stevo141
Re: No Network Capability
Post by sabayonino » Tue Nov 22, 2016 7:57
get the tarball at http://dl.sabayon.org/entropy/standard/ ... 58f~0.tbz2
and run from the downloaded folder :
# equo i net-misc:networkmanager-1.4.0-r1.56fff6dd78111f54c90476f59bd5008c5207b58f~0.tbz2
enable the service
 # systemctl enable NetworkManager
and cross the fingers
PS : do this for all required depedences if removed
Stevo141
Post by Stevo141 » Wed Nov 23, 2016 1:21
Whoa!!! It worked! I downloaded the tarball on another pc then copied it to the sabayon pc and ran the 1st step. I rec'd an error but tried the 2nd step anyway, then rebooted. System came up and connected automatically as always! Now, if I want to try WICD again after installing I would do the command: # systemctl disable NetworkManager? Is that correct?
Where are you located in Italy? We were just there a few years ago. Fly in and out of Venice and then by train to Florence and Rome. Great vacation!
Thank you for the quick reply, sabayonino
Stevo141
Post by sabayonino » Wed Nov 23, 2016 2:02
marked as SOLVED
please , consider to disable/anable NM or WICD the services for future use
keep in mind that both service can't run in the same time.
PS : I live near Venice :roll:
Stevo141
Re: No Network Capability [Solved]
Post by Stevo141 » Wed Nov 23, 2016 2:09
Thank you for marking thread as Solved. Trying to disable NM to use WICD is where I got into trouble. I deleted NM. Now everything seems to be working properly. I ran deptest and libtest and all looks good.
I live just north of Tampa, Florida USA.
Take care
