wifi realtek RTL8723be
Markinux
Post by Markinux » Thu May 12, 2016 0:21
I installed Sabayon 16.04 on my HP Pavilion X360, however, the wifi network not active, Realtek RTL8723BE. Please help me.
lspci -k :
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
Subsystem: Hewlett-Packard Company Sunrise Point-LP SMBus
Kernel modules: i2c_i801
00:1f.7 Non-Essential Instrumentation [1300]: Intel Corporation Device 9d26 (rev 21)
Kernel driver in use: intel_th_pci
Kernel modules: intel_th_pci
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
Subsystem: Hewlett-Packard Company RTL8723BE PCIe Wireless Network Adapter
Kernel driver in use: rtl8723be
Kernel modules: rtl8723be
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 0a)
Subsystem: Hewlett-Packard Company RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
Kernel driver in use: r8169
Kernel modules: r8169
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
Subsystem: Hewlett-Packard Company RTS522A PCI Express Card Reader
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
[email protected] markinux #
Re: wifi realtek RTL8723be
Post by sabayonino » Thu May 12, 2016 17:53
Hi
wifi module is loaded
check NetwokManager service status :
# systemctl status NetworkManager.service
Markinux
Post by Markinux » Fri May 20, 2016 14:23
sabayonino wrote:Hi
Hi, thanks, return of the check:
[email protected] markinux # systemctl status NetworkManager.service
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib64/systemd/system/NetworkManager.service; enabled; vendor preset: disabled)
Active: active (running) since Sex 2016-05-20 08:36:04 BRT; 1h 39min ago
Main PID: 2021 (NetworkManager)
CGroup: /system.slice/NetworkManager.service
├─2021 /usr/sbin/NetworkManager --no-daemon
└─2858 /sbin/dhclient -d -q -sf /usr/libexec/nm-dhcp-helper -pf /var/run/dhclient-enp0s20f0u3.pi...
Mai 20 10:11:24 markinux-x360 dhclient[2858]: DHCPREQUEST on enp0s20f0u3 to 192.168.42.129 port 67
Mai 20 10:11:24 markinux-x360 dhclient[2858]: DHCPACK from 192.168.42.129
Mai 20 10:11:24 markinux-x360 NetworkManager[2021]: <info> address 192.168.42.42
Mai 20 10:11:24 markinux-x360 NetworkManager[2021]: <info> plen 24 (255.255.255.0)
Mai 20 10:11:24 markinux-x360 NetworkManager[2021]: <info> gateway 192.168.42.129
Mai 20 10:11:24 markinux-x360 NetworkManager[2021]: <info> server identifier 192.168.42.129
Mai 20 10:11:24 markinux-x360 NetworkManager[2021]: <info> lease time 3600
Mai 20 10:11:24 markinux-x360 NetworkManager[2021]: <info> nameserver '192.168.42.129'
Mai 20 10:11:24 markinux-x360 NetworkManager[2021]: <info> (enp0s20f0u3): DHCPv4 state changed bound -> bound
Mai 20 10:11:24 markinux-x360 dhclient[2858]: bound to 192.168.42.42 -- renewal in 1515 seconds.
Hint: Some lines were ellipsized, use -l to show in full.
I do not understand, it seems okay, but when I click on the wifi return is unavailable and turns itself off quickly.
My hardware is Pavillion x360 HP.
Post by sabayonino » Fri May 20, 2016 17:44
kernel in use ?
I had similar issue with 4.4.x kernel version , solved with 4.5
Markinux
Post by Markinux » Sat May 21, 2016 0:03
[email protected] ~ $ Linux version 4.4.0-sabayon ([email protected]) (gcc version 4.9.3 (Gentoo Hardened 4.9.3 p1.1, pie-0.6.2) ) #1 SMP Sat May 14 18:04:56 UTC 2016
Markinux
Post by Markinux » Sat May 21, 2016 0:06
how do I install version 4.5?
Post by sabayonino » Sat May 21, 2016 11:39
...running kernel-switcher
$ sudo kernel-switcher switch linux-sabayon:4.5 --ask
