Wallpapers
BradHeff
Wallpapers
Post by BradHeff » Thu Apr 07, 2016 17:14
Re: Wallpapers
Post by wolfden » Fri Apr 08, 2016 20:58
Nice! Keep em coming :)
Re: Wallpapers
Post by wolfden » Fri Apr 08, 2016 21:28
BradHeff
Re: Wallpapers
Post by BradHeff » Sat Apr 09, 2016 4:20
thanks :) i have others in my tinypic album different colour variations if you wish to add them also.
http://i68.tinypic.com/of2dl4.jpg
http://i68.tinypic.com/of2dl4.jpg[/img2]
http://i68.tinypic.com/2vuet8x.jpg
http://i68.tinypic.com/2vuet8x.jpg[/img2]
Re: Wallpapers
Post by wolfden » Sat Apr 09, 2016 5:33
awesome :)
BradHeff
Re: Wallpapers
Post by BradHeff » Sat Apr 09, 2016 7:54
BradHeff
Re: Wallpapers
Post by BradHeff » Sat Apr 09, 2016 11:09
thanks for posting the links sabayonino, you should be able to just right click the image and select "view image" (depending on your browser) if you dont have that option then "copy image location" will give you the link also.
Re: Wallpapers
Post by sabayonino » Sat Apr 09, 2016 13:02
BradHeff wrote:thanks for posting the links sabayonino, you should be able to just right click the image and select "view image" (depending on your browser) if you dont have that option then "copy image location" will give you the link also.
quoting your post and get image links :mrgreen:
(or used source code page)
next time paste the links at the top or at the bottom of the images without img /img tags
(but other images hosting provides more options to get other image links type)
http://i63.tinypic.com/16iz6vo.png
BradHeff
Re: Wallpapers
Post by BradHeff » Sat Apr 09, 2016 14:22
NP edited above posts with the links :)
