Emerge sys-kernel/linux-sabayon
reppk
Post by reppk » Tue Apr 05, 2016 10:17
Hi, it's me again.....
When I emerged sys-kernel/linux-sabayon, I always get error like this:
>>> Emerging (1 of 2) sys-kernel/linux-sabayon-4.5::sabayon-distro
 * linux-4.5.tar.xz SHA256 SHA512 WHIRLPOOL size ;-) ...                 [ ok ]
 * 4.5-sabayon-4.5.patch.xz SHA256 SHA512 WHIRLPOOL size ;-) ...         [ ok ]
 * Preparing kernel and its modules
>>> Unpacking source...
>>> Unpacking linux-4.5.tar.xz to /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work
 * Excluding Patch #5000_enable-additional-cpu-optimizations-for-gcc.pat [ ok ]
 * Excluding Patch #5015_kdbus*.patch ...                                [ ok ]
 * Applying 4.5-sabayon-4.5.patch.patch (-p1) ...                        [ ok ]
>>> Source unpacked in /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work
>>> Preparing source in /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/linux-4.5.0-sabayon ...
>>> Source prepared.
>>> Configuring source in /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/linux-4.5.0-sabayon ...
>>> Source configured.
>>> Compiling source in /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/linux-4.5.0-sabayon ...
 * Starting to compile kernel...
 * Using kernel config: /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/linux-4.5.0-sabayon/sabayon/config/sabayon-amd64.config
* Gentoo Linux Genkernel; Version 63
* Running with options: --no-menuconfig --no-save-config --e2fsprogs --udev --btrfs --plymouth --plymouth-theme=sabayon-artwork-plymouth-default --dmraid --iscsi --mdadm --luks --lvm --compress-initramfs-type=gzip --kerneldir=/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/linux-4.5.0-sabayon --kernel-config=/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/config --cachedir=/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/cache --makeopts=-j16 --tempdir=/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/linux-4.5.0-sabayon/temp --logfile=/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/genkernel.log --bootdir=/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/boot --mountboot --module-prefix=/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/lib all
* Using genkernel.conf from /etc/genkernel.conf
* Sourcing arch-specific config.sh from /usr/share/genkernel/arch/x86_64/config.sh ..
* Sourcing arch-specific modules_load from /usr/share/genkernel/arch/x86_64/modules_load ..
* Linux Kernel 4.5.0-sabayon for x86_64...
* .. with config file /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/config
* kernel: Using config from /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/config
* kernel: >> Running mrproper...
*         >> Running oldconfig...
* kernel: >> Cleaning...
*         >> Compiling 4.5.0-sabayon bzImage...
*         >> Not installing firmware as it's included in the kernel already (CONFIG_FIRMWARE_IN_KERNEL=y)...
*         >> Compiling 4.5.0-sabayon modules...
*         >> Generating module dependency data...
* busybox: >> Applying patches...
*           - 1.18.1-openvt.diff
*           - busybox-1.20.1-strict-atime.patch
*           - busybox-1.20.2-glibc-sys-resource.patch
*           - busybox-1.7.4-signal-hack.patch
* busybox: >> Configuring...
* busybox: >> Compiling...
* busybox: >> Copying to cache...
* initramfs: >> Initializing...
*         >> Appending base_layout cpio data...
mknod: console: Operation not permitted
* ERROR: cannot mknod
* -- Grepping log... --
*  CC      block/blk-lib.o
*  CC      mm/vmpressure.o
*  CC      arch/x86/kernel/cpu/perf_event_intel_uncore_snb.o
*  CC      arch/x86/pci/init.o
*  CC      arch/x86/kernel/amd_nb.o
*  CC      mm/memory-failure.o
*  LD      drivers/scsi/megaraid/built-in.o
*  CC      drivers/scsi/dpt_i2o.o
*  CC      drivers/scsi/libfc/fc_npiv.o
*  CC      drivers/scsi/lpfc/lpfc_attr.o
*  CC      drivers/scsi/ips.o
*drivers/scsi/dpt_i2o.c:183:29: warning: ‘dptids’ defined but not used [-Wunused-variable]
*  LD      drivers/scsi/built-in.o
*  LD      drivers/built-in.o
*  LINK    vmlinux
*  LD      vmlinux.o
*  MODPOST vmlinux.o
*WARNING: modpost: Found 1 section mismatch(es).
*  CC [M]  net/netfilter/xt_bpf.o
*  CC [M]  drivers/gpu/drm/gma500/oaktrail_lvds.o
*  CC [M]  net/netfilter/xt_cluster.o
*  LD [M]  drivers/gpu/drm/amd/amdkfd/amdkfd.o
*drivers/gpu/drm/gma500/cdv_intel_dp.c: In function ‘cdv_intel_dp_i2c_init’:
*drivers/gpu/drm/gma500/cdv_intel_dp.c:868:2: warning: ‘i2c_dp_aux_add_bus’ is deprecated (declared at drivers/gpu/drm/gma500/cdv_intel_dp.c:224) [-Wdeprecated-declarations]
*  CC [M]  drivers/gpu/drm/gma500/mdfld_dsi_pkg_sender.o
*  CC [M]  drivers/gpu/drm/gma500/mdfld_tpo_vid.o
*  CC [M]  net/netfilter/xt_cpu.o
*  CC [M]  drivers/gpu/drm/amd/amdgpu/amdgpu_display.o
*  CC [M]  drivers/gpu/drm/amd/amdgpu/amdgpu_i2c.o
*drivers/gpu/drm/gma500/mdfld_dsi_output.c:407:2: warning: initialization from incompatible pointer type
*  .dpms = /*drm_helper_connector_dpms*/mdfld_dsi_connector_dpms,
*drivers/gpu/drm/gma500/mdfld_dsi_output.c:407:2: warning: (near initialization for ‘mdfld_dsi_connector_funcs.dpms’)
*  CC [M]  drivers/video/fbdev/core/fb_sys_fops.o
*  CC [M]  drivers/video/fbdev/aty/radeon_i2c.o
*  CC [M]  drivers/video/fbdev/aty/radeon_backlight.o
*  CC [M]  drivers/watchdog/sbc_fitpc2_wdt.o
*  CC [M]  drivers/xen/xen-pciback/pci_stub.o
*  CC [M]  drivers/staging/lustre/lustre/libcfs/fail.o
*  HOSTCC  scripts/basic/fixdep
*  GEN     include/applets.h
*  HOSTCC  scripts/basic/docproc
*  HOSTCC  scripts/basic/split-include
*scripts/basic/split-include.c: In function ‘main’:
*scripts/basic/split-include.c:134:6: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result [-Wunused-result]
*  GEN     findutils/Config.in
*  GEN     selinux/Kbuild
*  GEN     selinux/Config.in
*  HOSTCC  scripts/kconfig/conf.o
*scripts/kconfig/conf.c: In function ‘conf_askvalue’:
*scripts/kconfig/conf.c:106:3: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result [-Wunused-result]
*   fgets(line, 128, stdin);
*scripts/kconfig/conf.c: In function ‘conf_choice’:
*scripts/kconfig/conf.c:354:4: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result [-Wunused-result]
*  SHIPPED scripts/kconfig/zconf.tab.c
*  SHIPPED scripts/kconfig/zconf.hash.c
*  HOSTCC  scripts/kconfig/mconf.o
*  SHIPPED scripts/kconfig/lex.zconf.c
*scripts/kconfig/mconf.c: In function ‘show_textbox’:
*scripts/kconfig/mconf.c:839:2: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
*  write(fd, text, strlen(text));
*scripts/kconfig/mconf.c: In function ‘exec_conf’:
*scripts/kconfig/mconf.c:473:2: warning: ignoring return value of ‘pipe’, declared with attribute warn_unused_result [-Wunused-result]
*  pipe(pipefd);
*  HOSTCC  scripts/kconfig/zconf.tab.o
*  HOSTLD  scripts/kconfig/conf
*scripts/kconfig/conf -o Config.in
*.config:45:warning: trying to assign nonexistent symbol PID_FILE_PATH
*.config:100:warning: trying to assign nonexistent symbol SHA3_SMALL
*.config:268:warning: trying to assign nonexistent symbol SHA3SUM
*.config:621:warning: trying to assign nonexistent symbol FEATURE_VOLUMEID_EXFAT
*.config:625:warning: trying to assign nonexistent symbol FEATURE_VOLUMEID_NILFS
*.config:633:warning: trying to assign nonexistent symbol FEATURE_VOLUMEID_SQUASHFS
*.config:1027:warning: trying to assign nonexistent symbol FEATURE_KMSG_SYSLOG
*Additional LDLIBS (EXTRA_LDLIBS) []
* Debugging Options
*Build BusyBox with extra Debugging symbols (DEBUG) [N/y/?] n
*Abort compilation on any warning (WERROR) [N/y/?] n
*  Tab completion (FEATURE_TAB_COMPLETION) [Y/n/?] y
*    Username completion (FEATURE_USERNAME_COMPLETION) [N/y/?] n
*  Fancy shell prompts (FEATURE_EDITING_FANCY_PROMPT) [N/y/?] n
*  Query cursor position from terminal (FEATURE_EDITING_ASK_TERMINAL) [N/y/?] n
*Non-POSIX, but safer, copying to special nodes (FEATURE_NON_POSIX_CP) [Y/n/?] y
*Give more precise messages when copy fails (cp, mv etc) (FEATURE_VERBOSE_CP_MESSAGE) [N/y/?] n
*Copy buffer size, in kilobytes (FEATURE_COPYBUF_KB) [4] 4
*Skip rootfs in mount table (FEATURE_SKIP_ROOTFS) [Y/n/?] y
*Use clock_gettime(CLOCK_MONOTONIC) syscall (MONOTONIC_SYSCALL) [Y/n/?] y
*Use ioctl names rather than hex values in error messages (IOCTL_HEX2STR_ERROR) [Y/n/?] y
*bbconfig (BBCONFIG) [N/y/?] n
*beep (BEEP) [Y/n/?] y
*  default frequency (FEATURE_BEEP_FREQ) [4000] 4000
*  default length (FEATURE_BEEP_LENGTH_MS) [30] 30
*chat (CHAT) [Y/n/?] y
*  Enable NOFAIL expect strings (FEATURE_CHAT_NOFAIL) [Y/n/?] y
*  SPLIT   include/autoconf.h -> include/config/*
*  HOSTCC  applets/applet_tables
*  HOSTCC  applets/usage
*  GEN     include/bbconfigopts.h
*applets/usage.c: In function ‘main’:
*applets/usage.c:52:3: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
*   write(STDOUT_FILENO, usage_array[i].usage, strlen(usage_array[i].usage) + 1);
*applets/applet_tables.c: In function ‘main’:
*applets/applet_tables.c:144:4: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      archival/libarchive/decompress_bunzip2.o
*  CC      archival/libarchive/data_skip.o
*  LD      console-tools/built-in.o
*In file included from archival/bzip2.c:51:0:
*archival/libarchive/bz/compress.c: In function ‘sendMTFValues’:
*archival/libarchive/bz/compress.c:505:6: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*      | *(uint32_t*)&(s->inUse[i * 16 + 4])
*archival/libarchive/bz/compress.c:506:6: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*      | *(uint32_t*)&(s->inUse[i * 16 + 8])
*archival/libarchive/bz/compress.c:507:6: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*      | *(uint32_t*)&(s->inUse[i * 16 + 12])) != 0);
*archival/libarchive/bz/compress.c:511:6: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*      | *(uint64_t*)&(s->inUse[i * 16 + 8])) != 0);
*archival/libarchive/data_extract_all.c: In function ‘data_extract_all’:
*archival/libarchive/data_extract_all.c:176:4: warning: ignoring return value of ‘chown’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      console-tools/fgconsole.o
*  CC      archival/libarchive/header_list.o
*  CC      coreutils/chgrp.o
*  CC      archival/libarchive/header_skip.o
*console-tools/dumpkmap.c: In function ‘dumpkmap_main’:
*console-tools/dumpkmap.c:50:2: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
*  write(STDOUT_FILENO, "bkeymap", 7);
*console-tools/dumpkmap.c:59:2: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
*  write(STDOUT_FILENO, flags, MAX_NR_KEYMAPS);
*console-tools/dumpkmap.c:72:6: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      coreutils/df.o
*  CC      coreutils/date.o
*  CC      console-tools/loadkmap.o
*  CC      coreutils/dd.o
*console-tools/loadfont.c: In function ‘setfont_main’:
*console-tools/loadfont.c:404:4: warning: ignoring return value of ‘chdir’, declared with attribute warn_unused_result [-Wunused-result]
*    chdir(CONFIG_DEFAULT_SETFONT_DIR "/consolefonts");
*console-tools/loadfont.c:422:5: warning: ignoring return value of ‘chdir’, declared with attribute warn_unused_result [-Wunused-result]
*  LD      init/built-in.o
*  CC      coreutils/whoami.o
*  CC      coreutils/yes.o
*  CC      init/bootchartd.o
*editors/sed.c: In function ‘sed_main’:
*editors/sed.c:1471:4: warning: ignoring return value of ‘fchown’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      init/halt.o
*  CC      init/init.o
*  CC      findutils/xargs.o
*  CC      init/mesg.o
*init/bootchartd.c: In function ‘finalize’:
*init/bootchartd.c:310:2: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      mailutils/makemime.o
*  CC      miscutils/ionice.o
*  CC      miscutils/fbsplash.o
*  LD      networking/udhcp/built-in.o
*networking/ftpd.c: In function ‘popen_ls’:
*networking/ftpd.c:672:3: warning: ignoring return value of ‘dup’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      printutils/lpd.o
*  LD      procps/built-in.o
*  CC      procps/free.o
*  CC      procps/iostat.o
*mailutils/makemime.c: In function ‘makemime_main’:
*mailutils/makemime.c:197:3: warning: ignoring return value of ‘freopen’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      networking/udhcp/common.o
*  CC      miscutils/microcom.o
*  CC      printutils/lpr.o
*  CC      modutils/lsmod.o
*miscutils/man.c: In function ‘run_pipe’:
*miscutils/man.c:112:2: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      modutils/modinfo.o
*  CC      miscutils/mountpoint.o
*  CC      networking/ifenslave.o
*  CC      modutils/modprobe.o
*miscutils/microcom.c: In function ‘microcom_main’:
*miscutils/microcom.c:152:4: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
*    write(sfd, &c, 1);
*printutils/lpr.c: In function ‘lpqr_main’:
*printutils/lpr.c:252:3: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      libbb/default_error_retval.o
*  AR      runit/lib.a
*  CC      libbb/device_open.o
*In file included from networking/interface.c:34:0:
*networking/interface.c: In function ‘if_readlist_proc’:
*include/libbb.h:171:30: warning: ignoring return value of ‘fgets_unlocked’, declared with attribute warn_unused_result [-Wunused-result]
* # define fgets(s, n, stream) fgets_unlocked(s, n, stream)
*networking/interface.c:572:2: note: in expansion of macro ‘fgets’
*  fgets(buf, sizeof buf, fh); /* eat line */
*  AR      modutils/lib.a
*  CC      shell/ash.o
*  CC      procps/ps.o
*  CC      libbb/execable.o
*networking/nbd-client.c: In function ‘nbdclient_main’:
*networking/nbd-client.c:133:4: warning: ignoring return value of ‘daemon’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      libbb/fgets_str.o
*  CC      util-linux/acpid.o
*  AR      mailutils/lib.a
*shell/ash.c: In function ‘evalcommand’:
*  CC      util-linux/blkid.o
*shell/ash.c:9305:15: warning: variable ‘oldpath’ set but not used [-Wunused-but-set-variable]
*  CC      libbb/herror_msg.o
*  CC      util-linux/hexdump.o
*  CC      util-linux/volume_id/luks.o
*  CC      libbb/human_readable.o
*libbb/hash_md5_sha.c: In function ‘common64_end’:
*libbb/hash_md5_sha.c:82:4: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*    *(uint64_t *) (&ctx->wbuffer[64 - 8]) = t;
*libbb/hash_md5_sha.c: In function ‘sha512_end’:
*libbb/hash_md5_sha.c:881:4: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*    *(uint64_t *) (&ctx->wbuffer[128 - 8]) = t;
*libbb/hash_md5_sha.c:884:4: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*  CC      util-linux/mkfs_ext2.o
*  CC      util-linux/volume_id/util.o
*  CC      util-linux/volume_id/volume_id.o
*  CC      util-linux/volume_id/xfs.o
*util-linux/mdev.c: In function ‘make_device’:
*util-linux/mdev.c:564:5: warning: ignoring return value of ‘symlink’, declared with attribute warn_unused_result [-Wunused-result]
*     symlink(node_name, "root");
*util-linux/mdev.c:567:5: warning: ignoring return value of ‘chown’, declared with attribute warn_unused_result [-Wunused-result]
*     chown(node_name, rule->ugid.uid, rule->ugid.gid);
*util-linux/mdev.c:574:6: warning: ignoring return value of ‘symlink’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      libbb/vfork_daemon_rexec.o
*  CC      libbb/warn_ignoring_args.o
*  CC      libbb/wfopen.o
*  CC      libbb/wfopen_input.o
*libbb/update_passwd.c: In function ‘update_passwd’:
*libbb/update_passwd.c:138:3: warning: ignoring return value of ‘fchown’, declared with attribute warn_unused_result [-Wunused-result]
*  CC      libbb/xgethostbyname.o
*  CC      libbb/xreadlink.o
*  CC      libbb/xrealloc_vector.o
*  CC      libbb/xregcomp.o
*libbb/xfuncs_printf.c: In function ‘generate_uuid’:
*libbb/xfuncs_printf.c:593:3: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result [-Wunused-result]
* -- End log... --
* Please consult /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/genkernel.log for more information and any
* errors that were reported above.
* Report any genkernel bugs to bugs.gentoo.org and
* assign your bug to [email protected] Please include
* as much information as you can in your bug report; attaching
* /var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/genkernel.log so that your issue can be dealt with effectively.
* Please do *not* report compilation failures as genkernel bugs!
 * ERROR: sys-kernel/linux-sabayon-4.5::sabayon-distro failed (compile phase):
 *   genkernel failed
 * Call stack:
 *     ebuild.sh, line  133:  Called src_compile
 *   environment, line 4847:  Called sabayon-kernel_src_compile
 *   environment, line 4755:  Called _kernel_src_compile
 *   environment, line  624:  Called die
 *       DEFAULT_KERNEL_SOURCE="${S}" CMD_KERNEL_DIR="${S}" genkernel "${GKARGS[@]}" ${K_GENKERNEL_ARGS} --kerneldir="${S}" --kernel-config="${WORKDIR}"/config --cachedir="${WORKDIR}"/cache --makeopts="${mkopts}" --tempdir="${S}"/temp --logfile="${WORKDIR}"/genkernel.log --bootdir="${WORKDIR}"/boot --mountboot --module-prefix="${WORKDIR}"/lib ${GENKERNEL_MODE} || die "genkernel failed";
 * If you need support, post the output of `emerge --info '=sys-kernel/linux-sabayon-4.5::sabayon-distro'`,
 * the complete build log and the output of `emerge -pqv '=sys-kernel/linux-sabayon-4.5::sabayon-distro'`.
 * The complete build log is located at '/var/tmp/portage/sys-kernel/linux-sabayon-4.5/temp/build.log'.
 * The ebuild environment file is located at '/var/tmp/portage/sys-kernel/linux-sabayon-4.5/temp/environment'.
 * Working directory: '/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/linux-4.5.0-sabayon'
 * S: '/var/tmp/portage/sys-kernel/linux-sabayon-4.5/work/linux-4.5.0-sabayon'
What's the problem? How to fix it? Thx!
Re: Emerge sys-kernel/linux-sabayon
Post by sabayonino » Tue Apr 05, 2016 11:11
Do you need sabayon-sources ? (to compile sabayon kernel by yourself)
# equo i sabayon-sources:4.5
Do you need linux-sabayon binary package ?
# equo i linux-sabayon:4.5
nothing to merge
reppk
Post by reppk » Tue Apr 05, 2016 14:59
sabayonino wrote:Do you need sabayon-sources ? (to compile sabayon kernel by yourself)
nothing to merge
Yes, I want to use portage package manager. The problem is not only for linux-sabayon-4.5. It happens whe I want to build 4.4.5 & 4.4.6 as well.
I got linux-sabayon-4.4.6 (Sabayon 16.04 build-in ) and sabayon-sources-4.4.6 (emerged) in my system now.
PS: It seems that linux-sabayon is not in Entropy yet.
mudler
Post by mudler » Tue Apr 19, 2016 17:52
add FEATURES="-userpriv" in front of the emerge command
