Not quite sure what to put package.mask
Honeyman
Post by Honeyman » Mon Feb 01, 2016 15:46
Hi all,
after purging my system from unneeded libraries and packages not in the repositories anymore, I realized that I miss some packages. I overlooked that they would be removed as well.
Among is the nice quick launcher tool called gnome-do.
This is no longer maintained in the entropy store, but available via portage. I read through the wiki article for using Portage in parallel with Entropy https://wiki.sabayon.org/?title=HOWTO:_ ... nd_Portage.
There is an example in /etc/entropy/packages/package.mask, but I'm not quite sure, if I masked it correctly (as it is no longer in the Sabayon repositories, that step may not be necessary in the first place, but safe than sorry)
>=gnome-extra/gnome-do
<gnome-extra/gnome-do
Is that correct?
Thanks for your help
Je me regarde pour me désoler,
je me compare pour me consoler
Maurice de Talleyrand
Re: Not quite sure what to put package.mask
Post by sabayonino » Mon Feb 01, 2016 19:53
Right : Mask all gnome-extra/gnome-do versions
Wrong :
Is need to put versions(s) package to mask
>gnome-extra/gnome-do-0.9
this mask all gnomedo version higher than 0-9 (0.9 excluded) (also <)
>=gnome-extra/gnome-do-0.9
same thing but 0.9 included (also =<)
you can mask slot version
sys-kernel/linux-sabayon:4.3
this mask all linux-sabayon kernels 4.3 series (4.3.3 4.3.4 ... and so on)
see /etc/entropy/packages/package.mask.example
# package.mask example file
# In this file you can specify dependencies, one per line, that you would like to mask.
# LINE CONSTRUCTION:
# <dependency to match>
# See examples below
# NOTE: for inline comments, please use "##" instead of "#"
# EXAMPLES:
# >=media-libs/foo-1.2.3
# media-libs/foo
# <media-libs/foo-1.2.3
# media-libs/foo:1
# >=media-libs/foo-1.2.3#2.6.23-sabayon-r1
# media-libs/foo::sabayon-repo
# :1 means package with SLOT="1"
# #2.6.23-sabayon-r1 means package with kernel tag = 2.6.23-sabayon-r1
if you need to run gnome-do , don't remove it
don't run
# equo upgeade --purge
ignore gnome-do warning message
Honeyman
Post by Honeyman » Mon Feb 01, 2016 20:40
Hi sabayonino,
thanks for the quick response. It was very helpful as it cleared things up. Now I understand the syntax. Might be helpful to add a few comments in the example file on how it works for future releases of Sabayon, so newbies like me find it easier to handle the distribution.
Post by sabayonino » Mon Feb 01, 2016 23:35
Honeyman wrote:Hi sabayonino,
equo --mask option can help yuo
# equo mask "packages"
apply the sintax above mentioned
# equo mask ">sys-kernel/linux-sabayon-4.3.3" "=<sys-kernel/linux-sabayon:4.2"
1- mask all linux-sabayon kernel higher than 4.3.3 (all kernels)
2 - mask linux-sabayon kernel lower/equal than 4.2 series
see
# equo mask --help
