No sound on 0AD [Solved]
A place where Linux Gamers can share their experience and help each other with Linux Games, native or emulated ;)
abufaris
Post by abufaris » Wed Jun 17, 2015 16:14
Not sure if this has cropped up before; but I am getting no sound whatsoever in 0AD.
I am running Sabayon Linux amd64 15.06 with Linux sabayon 4.0.0-sabayon kernel.
0Ad version: version: 0.0.17_alpha installed via equo.
I have this nagging suspicion this may have something to do with OpenAL and/or Pulseaudio.
Everything else sound related works fine on the box, but not 0AD. No error messages appear to be being generated about this issue. Any advice would be gratefully received.
abufaris
Re: No sound on 0AD
Post by abufaris » Thu Jun 18, 2015 3:45
But, hold there... having looked under /etc/portage/package.use/00-sabayon.package.use I notice under in the entry for 0AD that no sound USE flag is enabled.
Oh dear.
Re: No sound on 0AD
Post by joost » Fri Jun 19, 2015 0:08
https://github.com/Sabayon/build/commit ... 48910508e7
Should be fixed in the next revision update.
abufaris
Re: No sound on 0AD
Post by abufaris » Sat Jun 20, 2015 13:33
Excellent work, joost - many thanks.
I have edited the first post to read SOLVED.
