Orphaned files be removed?
deusr
Post by deusr » Tue Jun 02, 2015 11:08
I wonder if I remove the orphaned files without any problems?
neit talesam # equo q orphans
╠  @@ Búsca por Órfãos
╠  @@ Diretórios analizados: /bin /emul /etc /lib /lib32 /lib64 /opt /sbin /usr /var
╠  @@ Diretórios mascarados: /etc/entropy /etc/env.d /etc/gconf /etc/portage /etc/runlevels /etc/skel /etc/ssh /etc/ssl /lib/modules /lib/splash/cache /lib64/splash/cache /usr/lib/locale /usr/lib/scrollkeeper /usr/local /usr/portage /usr/share/mime /usr/src /var/cache /var/db /var/empty /var/lib /var/lib/init.d /var/log /var/mail /var/run /var/spool /var/spool/cron /var/tmp /var/www .*.pyc$ .*.pyo$ ^(/usr/lib/perl|/usr/lib64/perl).*.ph$ ^/usr/share/fonts/.*fonts.cache-1$ ^/usr/share/fonts/.*.dir$ ^/usr/share/icons/.*icon-theme.cache$ ^/.*/.keep$
╠  @@ Número de arquivos coletados no sistema de arquivos: 310234
╠  @@ Procurando dentre os pacotes já instalados: 310234
╠  @@ Número total de arquivos: 310234
╠  @@ Número de arquivos correspondentes: 279539
╠  @@ Número de arquivos tornados órfãos: 30695
╠  @@ Escrevendo arquivo no disco: /tmp/entropy-orphans.txt
╠  @@ Espaço total desperdiçado: 4459.0MB
deusr
Data de registro: Seg Fev 23, 2009 2:53
Re: Orphaned files be removed?
Post by joost » Tue Jun 02, 2015 13:17
Depends on what is in /tmp/entropy-orphans.txt
:D
(Mostly the answer is NO you will brick your system)
deusr
Post by deusr » Tue Jun 02, 2015 13:23
You have it:
http://talesam.org/entropy-orphans.txt
I have seen not! I do not know why says the files are orphans if they are used by the system: /
