equo libtest --> no matches for ...
ElDuderino
Post by ElDuderino » Wed Jun 18, 2014 23:30
when I run 'equo libtest', it gives me a notice about no matches for these libraries:
╠ => /usr/lib/libgnutls.so.26
╠ => /usr/lib/libgnutls.so.26.22.6
╠ => /usr/lib32/libgdk_pixbuf-2.0.so.0.2600.4
╠ => /usr/lib32/libgdk_pixbuf_xlib-2.0.so.0.2600.4
'equo deptest' finds no unresolved deps, i.e. says it's fine.
Is this normal? I'm running sabayonlinux.org + limbo.
Best,
ElDude
Re: equo libtest --> no matches for ...
Post by Fitzcarraldo » Tue Jun 24, 2014 2:33
I reckon they are all orphans that were left in your installation after you did something in the past. Check the situation:
# equo search --installed libgnutls
# equo search --installed gdk-pixbuf
# equo install mlocate
# updatedb
# locate libgnutls.so
# locate libgdk_pixbuf
If all the results returned show later versions, delete the four libraries you listed and rerun equo deptest && equo libtest.
