Unable to install unetbootin [Solved]
maccabbeo
Post by maccabbeo » Sat May 17, 2014 17:15
Hi to all,
I cannot install unetbootin package. Why?
This is the result of trying to install it through emerge http://pastebin.com/cuEtNRvx
Cannot install it through Rigo since it is unreliable at the moment due to continous crashing as described here viewtopic.php?f=54&t=31708
This is the content of the /var/tmp/portage/sys-boot/unetbootin-603/temp/build.log
http://pastebin.com/3dSciexG
What's wrong and what should I do?
Thanks,
regards.
linuxfluesterer
Re: Unable to install unetbootin
Post by linuxfluesterer » Sun May 18, 2014 4:39
Hallo Maccabbeo.
If Rigo fails, try to install a program in a root console, e.g. for unetbootin:
equo install unetbootin
Anyway, why do you want to use Unetbootin? If you only want to create a SabyonLive USB stick, then you can easily do that with the dd command. You can check your USB device as root with:
fdisk -l
So, provided your USB stick is on /dev/sdb, and is at least 4GByte of size, execute this as root:
dd if=<downloaded_iso_file.iso> of=/dev/sdb bs=4096
Be aware to write the whole device (sdb, not sdb1 or sdb2)...
Hope to help you.
Post by sabayonino » Sun May 18, 2014 10:19
..and regarding portage :
make: g++: Command not found
check g++
$ locate x86_64-pc-linux-gnu-g++
you'll have something like :
/usr/bin/x86_64-pc-linux-gnu-g++
/usr/bin/x86_64-pc-linux-gnu-g++-4.7.3
/usr/x86_64-pc-linux-gnu/gcc-bin/4.7.3/x86_64-pc-linux-gnu-g++
if not ...
Have you installed gcc ?
# equo i sys-devel/gcc
anyway , you can use "dd" command as Linuxfluesterer says
svantoviit
Post by svantoviit » Tue May 20, 2014 23:13
Seems you miss sys-devel/gcc and sys-devel/base-gcc.
If Rigo doesn't work properly use equo.
maccabbeo
Post by maccabbeo » Wed May 21, 2014 9:02
Yeah, that was the problem. How should I mark this thread as "Solved" ?
Also, is there any way to add attachments to the threads of this forum?
svantoviit
Post by svantoviit » Wed May 21, 2014 9:32
maccabbeo wrote:Yeah, that was the problem. How should I mark this thread as "Solved" ?
Why, and how to add "[Solved]" to your post. Please read.
maccabbeo wrote:Also, is there any way to add attachments to the threads of this forum?
The attachments feature has been disabled. So it isn't possible to add any attachments anymore.
For command line output, logs and such use the code tags.
maccabbeo
Re: Unable to install unetbootin [Solved]
Post by maccabbeo » Wed May 21, 2014 11:45
Done, thanks. However the code tags are not enough when you want to attach a dmesg output. I will use pastebin in such cases.
Post by sabayonino » Wed May 21, 2014 12:31
maccabbeo wrote:Done, thanks. However the code tags are not enough when you want to attach a dmesg output. I will use pastebin in such cases.
or http://pastebin.sabayon.org/ :roll:
